low boost, high EGT's
Old Jun 24, 2006 | 01:49 AM
paul2002's Avatar
'98.5 ,3500 ,24v, 5 speed While under load max boost 14 lb EGT up to 1400 then I back out. Edge comp box, 4" Turbo back, K&N. My '02 same setup but auto and wast gate J-hook by bully dog. 32lbs boost never over 1100 on the EGT's. Thanks for any help... Paul
Old Jun 24, 2006 | 08:14 AM
J BODY's Avatar
First thing I would do is to hook up my air charge tester and get the intake system up to psi and see if there are any obvious leaks. Pict of mine in my gallery.
Old Jun 24, 2006 | 01:41 PM
HiJenks's Avatar
I made a crude one from parts at Home Depot in Kileen texas to locate my leak. I had 11# boost at 2500rpm, major leak that could be heard inside cab but I couldn't find it until hooked up tester.
theres a picture in my gallery.
Old Jun 24, 2006 | 03:04 PM
high country's Avatar
look for the obvious leaks in the boots, pull the intake side of the turbo and give a wiggle/look for wear....if none is seen, build a leak tester.
Old Jun 24, 2006 | 09:44 PM
paul2002's Avatar
Thanks for the in put I was out of town today but will check for leaks in the am. it dont look too hard to build a leak tester. Thanks Again Paul
Old Jul 7, 2006 | 08:16 PM
neveragain's Avatar
cheap tester
Just get very soapy water and spray it around the boots and see if they leak???
Amos
Sep 6, 2009 10:45 AM
just_crankin_it
Mar 23, 2007 11:30 AM
jmccart
14
Nov 20, 2006 06:45 PM
napa 600
15
Feb 26, 2006 10:03 PM
