Loud ticking noise
Old Aug 25, 2009 | 06:29 PM
hotline1's Avatar
Loud ticking noise
#1 Today, 07:24 PM
hotline1
Registered User Join Date: Nov 2007
Loud ticking noise
i have loud ticking noise coming from top of engine need help have removed vavle cover looks ok
Old Aug 25, 2009 | 06:42 PM
BigIron70's Avatar
Cummins Guru
Check the valve clearance, if 24 valve make sure valve bridge didn't come off. Also cap on end of rocker arm will sometimes fall off. You can run engine with valve cover off to listen for location of noise better. Good Luck
Old Aug 25, 2009 | 06:54 PM
hotline1's Avatar
Thanks but every thing looks in place with the rockers
Old Aug 25, 2009 | 07:22 PM
Riflemanusmc's Avatar
Registered user
You NEED to check your valve lash. Looking at the will not help you. How many miles are on your rig?
Old Aug 26, 2009 | 01:40 PM
hotline1's Avatar
Getting ready to do that now just found out that the vent screws out but thanks for the advise
Old Aug 26, 2009 | 07:25 PM
hotline1's Avatar
All valves lashed good found no problem there whats next
Old Aug 26, 2009 | 09:11 PM
Registered user
Do you have a miss????
Old Aug 27, 2009 | 09:42 AM
infidel's Avatar
Go buy a $10 automotive stethoscope and pinpoint where the tick is coming from.
Also helps to know the truck's year and tranny.
Old Aug 27, 2009 | 03:54 PM
hotline1's Avatar
It is a 1999 auto with 95000 miles, Used stethoscope and narrowed the noise to the area around #2 and 3 cylinders near injecter line nuts, No miss, Today loosened injecter lines and could hear sound change when #2 loosened may be injecter
Old Aug 28, 2009 | 06:01 PM
hotline1's Avatar
Think I have found my problem #4 injecter when line loosened killed cylinder and noise went away have set of 60 hp's on the way thanks for the ideas
Old Sep 1, 2009 | 05:40 PM
hotline1's Avatar
Put in new injecters noise still there please help
1985cucv
Apr 11, 2010 10:42 AM
hotline1
Sep 4, 2009 12:30 AM
bsj21
17
Mar 9, 2008 10:25 AM
tboling
Jun 26, 2007 05:57 PM
