Ticking loud an hard!!
Old Jun 14, 2007 | 06:47 PM
tboling's Avatar
Unhappy Ticking loud an hard!!
MY engine stated ticking all at once an shaking, My valves were do for a good going over. So I set them at 8 an 18. I got in a hurry . At first they sounded great but the next day it started ticking and got louder then before an the motor still shakes. So I pulled the valve covers an checked them all again There were 3 ex vavles tite I could not get 18 under them . The ticking is not so bad now but sounds like it did before I started an still shakes. So I checked for ex leaks there were none, an injector temp by feel the all where close, My oil pressure is good,changed fuel filter and my egts are staying the same. Whats is going on here Im going to pop test my injectors after work tomorrow. If that dose nothing than I dont know Maybe the IP pump or a stoped up injector
Old Jun 15, 2007 | 03:12 AM
KRB's Avatar
KRB
This the same truck you dropped the dowel pin in? Could there be other damage from that event that you didn't catch? You had to replace the cam right?
Old Jun 15, 2007 | 04:52 PM
QIK2D's Avatar
i don't know what the piston to valve clearance is on these motors, but if you had em too tight then did a higher rpm run it may have made contact. worst case should just be a bent pushrod or a possible broken spring. just keep checking the valve clearances, if it keeps changing, check for bent or broke pieces.
Old Jun 15, 2007 | 05:05 PM
pred's Avatar
Set them at 10 and 20,,, From what i have heard if you have a collision between the piston and the valve, you will bend a pushrod first, Not too hard to check, But be careful when you pull the rocker block, there is an oiler in there, that you must be careful with!
Look at the pushrod ends, and roll em on a glass table to check for straightness!
Peter.
Old Jun 16, 2007 | 01:19 PM
dpuckett's Avatar
I second the notion to set at .010 and .020, at least til you get the ticking figured out. I didnt gain much by going to .009 and .019, but I'll leave them there for now.
It could be an injector. A bad injector can mimick a loose valve very easily.
Daniel
Old Jun 16, 2007 | 07:02 PM
pred's Avatar
A bad injector can sound like a wrench in the bore.
Old Jun 16, 2007 | 08:50 PM
TOMTOM's Avatar
O Travis This Problem Wouldin't Have Anthing To Do With The 3rd Gear Wot Launches We Did Sat Night Would It? I Thought My Neck Was Gonna Let Go Of My Head!!! Some Times We Pay For Having Too Mutch Fun. Let Me Know How Mutch I Owe Ya.
Tommy
Old Jun 17, 2007 | 05:36 AM
KRB's Avatar
KRB
Hey! You guys played after we all left?????
Old Jun 17, 2007 | 02:04 PM
tboling's Avatar
Thumbs up
I found the problem the # 5 hole had a worn out rocker arm. The ex valve was running to loose! thank god for that!
Old Jun 17, 2007 | 05:05 PM
jogl's Avatar
Where was the rocker arm wore out? Just curious.
JP.
Old Jun 17, 2007 | 05:07 PM
That's odd. I've seen the c-clip break so the rocker floats around on the shaft, but I haven't seen one wear out. You might want to pull the bridge off and make sure the oil passage is clear.
Old Jun 24, 2007 | 06:45 AM
jogl's Avatar
I'm still curious about that rocker arm. Was it wore out where it fits on to the shaft or was it wore where it pushes on the valve stem or somewhere else?
I wonder because I have a tractor I need to fix where the rocker arms have grooves worn in where they push on the valve stems. I'm hoping that I can grind the rocker arm ends back to "sort of" round.
JP.
Old Jun 26, 2007 | 05:57 PM
tboling's Avatar
It was chiped under the the adjuster, the ball that sets in the push rod. I have no idea Why? Sorry about the delay guys I have been working.
1985cucv
Apr 11, 2010 10:42 AM
hotline1
Sep 4, 2009 12:30 AM
bsj21
17
Mar 9, 2008 10:25 AM
