Loud ticking noise
Old Aug 25, 2009 | 05:45 PM
hotline1's Avatar
Question Loud ticking noise
i have developed a loud ticking noise coming from the upper part of the engine we used a stethascope to probe around and could here it in the exhaust and the area around number 2 and 3 cylinders removed valve cover and nothing out of place PLEASE HELP
Old Aug 25, 2009 | 11:06 PM
DodgenIt's Avatar
Fill out your sig under user cp so we know what kinda truck and mods you have so we can help better.
How often is the clicking? How close together time wise is the clicking? Does it always click? Or just when cold or hot?
Old Aug 26, 2009 | 01:45 PM
hotline1's Avatar
Just started a few days ago pulling my camper back up the mountians home to West Virigina after a week on a camping trip. It started about 100 miles from home and got steadly worse and is steady hot or cold and is loud enough to hear clear over the normal rattle of the cummins and seams to to be about like a cylinder revolution
Old Aug 26, 2009 | 07:27 PM
hotline1's Avatar
All valves lashed good every thing looks good any ideas
Old Aug 26, 2009 | 07:28 PM
hotline1's Avatar
all valves lashed good any ideas
Old Aug 26, 2009 | 10:05 PM
dozer12216's Avatar
It took a licking and now it's ticking!!! has blowby increased?? Is it losing oil??
Is it smoking more than normal?? A bad injector will make noise, and generally smokes somewhere in operating range. A broken ring will make a noise and have some extra blowby. A rod will tick intially and get worse rather quickly. Oil pressure test may not be conclusive till to late. Could hav eoil analysis done for some assistance.
Old Aug 27, 2009 | 04:04 PM
hotline1's Avatar
No blow by no oil loss getting white smoke at start this is new. I tested #1,2 and 3 by lossening fuel lines and noise seemed to change wih #2 may be injecter
Old Aug 27, 2009 | 08:16 PM
mooseman's Avatar
I had a tick I couldnt find for ever. It ended up being loose exhaust manifold bolts.
Old Aug 28, 2009 | 05:57 PM
hotline1's Avatar
Think I have found my problem #4 injecter when line loosened killed cylinder and noise went away have set of 60 hp's on the way thanks for the ideas
Old Sep 1, 2009 | 05:41 PM
hotline1's Avatar
Installed injecters and noise still there please help
Old Sep 1, 2009 | 09:29 PM
Huff nPuff's Avatar
If cracking #4
Quiets the noise,its probably a piston or connecting rod issue.
Old Sep 1, 2009 | 09:33 PM
Huff nPuff's Avatar
If cracking #4
Quiets the noise,its probably a piston or connecting rod issue.It also could be an exhaust leak.
Old Sep 4, 2009 | 12:30 AM
VICIOUS FISHER's Avatar
I had a similar noise (maybe) a slow but loud sharp tick, the best description I can think of is it sounded like a mechanical fuel pump tick. anyways I did an oil change (rotella 15w40) and it fixed it up. the noise did redevelop after 6000km another oil change a bottle of lucas diesel treatment through a couple of tanks and gone again I have NO idea what it was. It hasn't been back since
1985cucv
Apr 11, 2010 10:42 AM
hotline1
Sep 1, 2009 05:40 PM
bsj21
17
Mar 9, 2008 10:25 AM
tboling
Jun 26, 2007 05:57 PM
