Loud Bang
Old Nov 16, 2006 | 06:23 PM
infidel's Avatar
Do you know of any aftermarket boots that would be better than the stock ones?
The boots from http://www.piersdiesel.com/ are great. The whole set will cost you less than one boot at the dealer or you can buy just one. The one you found off by far is the one that gives the most problems.
Old Nov 16, 2006 | 10:21 PM
XLR8R's Avatar
The oil film on your impeller blades was probably from your air filter.
Old Nov 16, 2006 | 10:33 PM
DodgeCowboy's Avatar
DTR's Cow Boss
With the mods I have in my sig and nearing 90k on the clock how worried should i be about having a boot blow off. I know the one on the bottom of the passenger side is covered in grease and probably getting ate away. but the other or should i replace the problem one and go from there. If one was to buy just one from peirs would you also get the clamp also?
Old Nov 17, 2006 | 11:49 AM
Baggy's Avatar
XLR8R, you're probably right. The previous owner had cleaned and oiled it prior to selling and I think he may have been a bit overzealous in oiling the filter. After looking closer I noticed that the oil on the impeller wasnt the same as my motor oil.
Old Nov 17, 2006 | 12:06 PM
Baggy's Avatar
Infidel, thanks for the info. Been trying to get pricing info over the web but keep getting a server error from their site. will probably try and call them.I hear ya about the dealer. In fact the dealer I called here couldnt even find the part. they kept asking me for more info on what it exactly is, can you describe it..... sheesh.
Mountaineer
Dec 22, 2009 04:24 PM
Stockla@mpiins
Mar 19, 2008 03:33 PM
rdflick
Dec 27, 2003 11:35 PM
dansdad
Jun 22, 2003 05:34 PM
