Loud Bang And Quit
Old Dec 27, 2003 | 11:46 AM
rdflick's Avatar
Loud Bang And Quit
I HAVE A 12 VALVE B SERIES CUMMINS WITH MINOR MODS, 6 SPD ALLISON AND 63000 MILES. JUST LEFT HOUSE MADE LOUD POP IN ENGINE THEN QUIT. NOW WON'T START. HAS NOISE IN FRONT OF ENGINE WHILE CRANKING. TIMING GEARS?????
Old Dec 27, 2003 | 11:57 AM
BBWD's Avatar
rdflick:
Suspect that you have thrown the KDP (Killer Dowel Pin) that is used to align the timing gear cover if the noise was at the front of the engine. When this pin lets loose it can take a chunk out of the timing gear case, or worse, mess up the gears and cam. Check by examining the timing gear case. See post by gunracer1 in the 12v forum. He has posted a picture of what it can do when it lets loose. Good Luck!
John (DH)
Old Dec 27, 2003 | 04:01 PM
kandgo's Avatar
What year is the truck in question?? You state noise in front where the gears are,I would not try to start again til you at least tear into the front gear housing and check the gears on front of block. Goodluck and keep us informed. If you need to know any info on getting into the front gear housing let us know. Rick
Old Dec 27, 2003 | 05:00 PM
MCummings's Avatar
The KDP is the smaller/gray dot int the middle of the highlighted section.
That pin will just work it's way forwards, and fall out, right into the gears.
Merrick
By The Way, 6spd Allison huh? Sounds cool. What do you have the motor/tranny in?
(Typing in all capitols is considered yelling)
Old Dec 27, 2003 | 10:30 PM
Dieseldude4x4's Avatar
Is the KDP on the 12 valves or the 24 valvers or both?
There is one of each in my family.
Old Dec 27, 2003 | 11:35 PM
infidel's Avatar
The dowel pin has been reported to be a problem in '98.5 and '99 24 valves. I have personally seen the case cracked on one '99 from it.
Mountaineer
Dec 22, 2009 04:24 PM
Stockla@mpiins
Mar 19, 2008 03:33 PM
Baggy
Nov 17, 2006 12:06 PM
dansdad
Jun 22, 2003 05:34 PM
