loose steering
Old Jan 7, 2004 | 04:16 PM
cwbronc's Avatar
loose steering
I have known that there was some play in the steering for a while, but recently, my steering has gotten much worse. My 73 Scout II almost handles better. I think the track bar is bad, but could it also be the steering box (the gears inside)? Also, I've read about the Luke's Link...do I need a new track bar for that or does it fix the bad part of the track bar? I just made some money and trying to fix the worn out stuff. Thanks-Cody
Old Jan 7, 2004 | 04:53 PM
Luke's link website should answer all your questions. The DSS steering stabilizer has gotten rave reviews also.
Old Jan 7, 2004 | 10:24 PM
cwbronc's Avatar
Do I need both? The DSS looks like it may have a greater effect, but the price of the luke's link is better. -cody
Old Jan 7, 2004 | 10:29 PM
AggieJustin's Avatar
I think you'd probably see the greatest benefit from taking care of both, since they address different areas of wandering problem.
The track bar end allows more lateral axle movement as the bushing wears out, so now your axle is moving side to side under the front end giving you that wandering feeling.
The DSS takes care of lateral movement in the pitman arm shaft coming out of the steering box. When you get slack in the shaft, the tie rods gain extra play that allows the truck to steer left and right itself a little without input from the steering wheel.
My DSS took care of alot of wandering, but there's still a little left from the track bar that's getting worn out. Once I get it taken care of, it will probably feel better than brand new.
Leaky Gasket
Aug 14, 2008 07:17 AM
PurdellMGP
Aug 12, 2003 02:19 PM
Cumminsdude
Jul 7, 2003 11:44 PM
Holycack
Jun 28, 2003 10:42 AM
berner
Feb 9, 2003 07:37 PM
