lift pump question
Old Jun 22, 2008 | 05:52 PM
wildcard's Avatar
problem solved
Old Jun 22, 2008 | 06:41 PM
JWH_03_Dodge's Avatar
for the 04, the fuel pump should be located on the back side of the fuel filter housing. take a look there. if its trying to push the fuel through the stock pump, that could explain the low pressures
Someone else might be able to answer this, but the pressures you're seeing could be from a dead single pump and the result of the CP3 drawing the fuel through it.
Old Jun 22, 2008 | 07:03 PM
wildcard's Avatar
upon further inspection I think the previous owner just put one of the cheap pumps from autozone in there the the simple 2 wire 7psi inline pumps. I was looking could I pit a universal raptor pump in the same place.
Old Jun 22, 2008 | 07:07 PM
wildcard's Avatar
I looked on the back of the filter housing but I will look again I dont see anything that looks like it could be a pump, Im not mechanicly challanged, just not fimillar with this truck yet.
Old Jun 22, 2008 | 07:12 PM
could you verify that the pump is running or not? Bump the starter and you should be able to hear it running for 30 seconds or so. check to make sure they didn't leave the stock pump in place.
I'm not familiar with the raptor pump to answer it, but most aftermarket pumps are the same installation.
Keep in mind this forum is for immediate help, if its not for immediate help, i'd suggest moving the thread to the 3rd gen forum.
Txwelder
Nov 26, 2025 01:53 AM
ScreaminEagle
Oct 31, 2007 03:31 PM
Txwelder
May 19, 2005 06:10 PM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
