Lift pump fried???
Old Dec 17, 2005 | 03:50 PM
Rattletrap1's Avatar
Lift pump fried???
Was changing fuel filters on '01. Removed old, drained bowl, install new with o-ring. Lightly fitted cover, bumped starter, lift pump runs (hums), but no fuel into bowl. Removed filter...same thing...no fuel entering bowl with pump humming.
I take it my lift pump is fried? Please comfirm.
Old Dec 17, 2005 | 04:07 PM
Geico266's Avatar
Yes sir! That's why you need an in cab fuel pressure guage. You are lucky to have caught it before you took out your injection pump.
Can I ask you a question? I'm not trying to embarrass you, but after 600+ posts on DTR why haven't you put in a $50 guage that can save your $2,000 injection pump?
Old Dec 17, 2005 | 05:21 PM
chastising accepted...LOL. I guess I've just been lazy. I use the truck infrequently, but depend on it when I do. The gauges (full set) are on my Christmas list...of course they were on it last year too.
Old Dec 17, 2005 | 05:55 PM
Geico266's Avatar
Sorry, if I called you out. I'm glad you didn't take it negatively. I did the same thing for a month or two, then I put a FP guage on the filter housing and it was 3 PSI. So I changed the LP and added a FP guage. I think 75% of the VP failures are from not knowing when the LP fails.
Old Dec 17, 2005 | 08:00 PM
Been running like a raped ape. No sypmtoms, check engine light or anything.
I'd have to say it's unlikely it went bad today, but hopefully not long ago. With zero flow though...yikes.
FWIW...I filled the bowl by hand, squished a new filter in, and she fired right away, then died. Cranked for about 20 seconds and she fired again and stayed lit.
No problem giving me hell...deserve it, as I know better. Just thought I could get away with out it until I got around to it.
Old Dec 20, 2005 | 01:04 PM
blackdiesel's Avatar
Registered
LOL it was after 1000 posts before i got around to installing mine.
Old Dec 21, 2005 | 08:02 AM
Joe Diesel's Avatar
1st mod i did @ 200km was install gauges cause of this site
Old Dec 22, 2005 | 10:06 PM
Well...the good news. Installed replacement pump from Cummins. Primes proper now. Hopefully my injector pump didn't get stressed. Should I worry? She was getting enough fuel to blow a bit of black smoke when the hammer was down. These events were very brief and seldom.
Considered DC intank and FASS. Next time. Dealer wanted $1000 total (nearly $700 labor) plus I'd have to remove my cabover. Closest FASS dealer was out of stock. No free time for more extensive install. Need the truck for the holidays. I'll take another look when time is on my side.
Gauges don't add horsepower. If DC felt we should have gauges they would've put them on factory (just kidding).
Fronty Owner
Apr 21, 2008 09:43 PM
Hasselholf
Oct 29, 2006 07:07 PM
busternkashe
Jul 4, 2006 01:15 AM
Dodgezilla
Nov 30, 2004 01:00 PM
PowerTurbonanda
Jan 10, 2004 04:45 PM
