Lift Pump
Originally posted by heavyboostin
****, oh well, guess ill have to get the lift pump and do it my self.what are you thought on drving the truck even though the lift pump is tticking.?
Doesn't matter anyway, if the pump is ticking as you say it should be replaced no matter what the fuel pressure is. Drive it, but the pump should be replaced, the ticking you hear is the pump actuator arm pounding away against the cam, over time this can damage the cam.
ok, well i got a lift pump for 128 today from a local diesel injection shop. so ia m jsut gona replace it, also ordered a over flow valve and fuel filter.
Thank you guys for all your help, this website is a huge help, espeacially for a newbie like me.
what is the best way to do a pressure test., also, if it is these valves, how hard are they to replace and were exactly are they located? any directions or schematics?
The one way check valves are inside the pump and are not sold seperately that I know of. If you have an old pump you might be able to swap them out.
got er did, everything seems to be workin well, no more ticken, the lift pump was messed up, it almost looked like it was gettin bored out by the plunger, the end of the pipe were the plunger comes out was all beat up and outa round, but good news is the new one is in and ready to go, engine seems to be running smoother but i guess it could be my imagination, over flow valve is next on the agenda.
The ticking and beat up arm is caused when the arm return spring gets weak or broken. The arm doesn't keep in contact with the cam the whole time, every time it recontacts the cam it ticks and beats things up a little more.
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
