Which Lift Pump??
Old Apr 4, 2008 | 09:17 PM
brummer9's Avatar
Which Lift Pump??
Hey everyone my lift pump is going out and I was wonderin what lift pump i should get. I was lookin at the BD lift pumps and I was wonderin what the difference between the Auxillary pump and the OEM bypass kit was?? Which one do u guys prefer i should get?? Or should I get another one?? Thanks
Old Apr 4, 2008 | 09:26 PM
53 willys's Avatar
lots of good options...but I dont like the BD pumps cause they are the same pump that fails like crazy on the 2nd gen trucks..my vote would be a raptor fuel pump or a airdog...or a walbro pump...my.02
Old Apr 4, 2008 | 09:33 PM
doorguy's Avatar
just had the bd kit put on and they put on the booster pump kit on when the should have put on the oem replacement kit. Differences are the booster pump is turned on by oil pressure and supplies more fuel to your good working lift pump. The oem replacement kit has an adaptor plate to remove the oem lift pump, gets power from the original plug so it turns on with the key.
If you have a bad lift pump get the oem replacement kit, if your lift pump is good get the booster pump.
I got this kit because it was all I could find quickly, but had alot of hassel because of getting the wrong kit but that was the companies fault here in town.
Old Apr 4, 2008 | 09:37 PM
brummer9's Avatar
Will the oem replacement kit add more fuel faster than the stock lift pump??
Old Apr 4, 2008 | 09:44 PM
brummer9's Avatar
hey 53 ****** where would I go on the internet to find those lift pumps im havin a lil trouble findin them?? thanks
Old Apr 4, 2008 | 09:50 PM
JP-4.5's Avatar
http://www.glacierdieselpower.com/gdept.aspx?dept_id=09
Old Apr 4, 2008 | 09:58 PM
brummer9's Avatar
Hey JP-4.5 thanks a lot! I think I made my choice!! Thanks again
Old Apr 4, 2008 | 10:13 PM
JP-4.5's Avatar
Do not overlook the 2 micron filters. It never hurts to make sure clean fuel is all that makes it thru your system.
No commissions made from GDP. I have bought one kit from them for my truck. It was very easy and clear to install. Good Luck with yours.
Old Apr 4, 2008 | 10:31 PM
53 willys's Avatar
I can get you the Raptor or Airdog pumps if your interested..just let me know..I have a link in my sig..
dont forget the Raptor and Airdog have LIFETIME WARRANTY!!!!
Txwelder
Nov 26, 2025 01:53 AM
Bradleysram
19
May 12, 2009 08:36 AM
Txwelder
May 19, 2005 06:10 PM
lucey
Apr 21, 2005 09:53 PM
Dieselcamper
Mar 2, 2005 07:40 PM
