Leaking Injectors!!!
Old Oct 22, 2007 | 03:49 PM
dieselfreak12's Avatar
Exclamation Leaking Injectors!!!
Ok so I get home from school and as much as I love the smell of diesel in cool weather I smelled really strong raw diesel. So I took a look under the hood and first thing I saw was puddles around # 2-6 injectors. And you can see where the diesel has been runnin down the side of the block. The thing is its not leaking at the nut/line its leaking closer to the base can't really tell exactly on the base. Is it time for new injectors? I already have some in mind but just want to make sure since I have no experience with injectors other than how they work. Any help would be great I need my truck to pull my tractor this week thanks!
Old Oct 22, 2007 | 03:52 PM
redramnc's Avatar
New sealing washers for the return lines. Try tightening them a bit and see if it helps. Could possibly be a cracked injector but more than likely a line problem.
Old Oct 22, 2007 | 10:40 PM
sorry for the late reply I found out it wasn't dieasel at all! It was oil leaking around 2-4 in the center. The diesel smell was actually from the lift pump leaking. Got some new felpro seals for about 3.99 each and goin to get a new left pump soon. Thanks for the reply!
lilsuzuki4x4
Sep 1, 2011 01:50 AM
KRB
May 20, 2007 06:20 PM
CRXsi
Jul 26, 2004 07:03 AM
BIGOKIE
Jul 21, 2004 05:53 PM
Sidewinder
May 1, 2004 09:48 PM
