Lamp Out
Old Sep 3, 2005 | 09:20 AM
justcampin's Avatar
Lamp Out
The lamp out light came on when I touch the brake pedal, I check the top right brake bulb is out so I replaced it..did not fix..The turn signal which is the same bulb works fine. It is not the cluster because I swapped with the outher side just to check. what could it be
Old Sep 3, 2005 | 01:54 PM
justcampin's Avatar
Anybody have any idea... the chime is driving me crazy every time I touch the brake pedal
Old Sep 3, 2005 | 03:37 PM
phox_mulder's Avatar
3 day weekend.
Most folks "in the know" are probably getting one last weekend of camping in.
Give it time.
phox
Old Sep 3, 2005 | 05:02 PM
ClFuller's Avatar
Lamp out
There's another thread on this subject. Seems the chime was coming on before any lights went out. Try changing the bulb on the other side. You're having an indication of a bulb being out before it is... from the thread this fixed the other one. Could be resistance and not just continuity being checked for the reading.
Old Sep 3, 2005 | 06:45 PM
J BODY's Avatar
Pull the rear bulbs paying close attention to the base of the bulbs. You may find the terminals melted into the plastic base. Replace the bulbs, or pry the terminals out a little. Also clean the socket where the bulb goes in and tighten the connectors there.
Old Sep 4, 2005 | 03:45 PM
Dodgezilla's Avatar
I had the same problem last week and just changed all the bulbs out on the advise of members here. While I had both lights apart I noticed that both center lights were turning brown on the plastic base plus the glass was starting to get a black tint to it. I still changed all the bulbs and I have not had one chime since then. All my lights were working fine during all this...
Other members have had to replace the whole circuit board that the bulbs plug into. Those cost about $25.00 each.....
Old Sep 4, 2005 | 08:06 PM
justcampin's Avatar
I changed all the bulbs on the back and the chime is gone
Thanks guys
Hoss
21
Dec 3, 2016 02:49 PM
Pickle
Mar 26, 2005 11:57 PM
Desert Diesel
Dec 9, 2004 10:03 PM
dodgedude361
16
Feb 27, 2004 07:31 PM
