Shudder when turning
Old Sep 3, 2005 | 11:00 AM
coiler33's Avatar
I have a shudder when turning from a stop. It seems like its is tranny related. Could it be my TC? Thanks for input.
Old Sep 3, 2005 | 11:27 AM
artman1308's Avatar
Is it coming from the front or back?
Old Sep 3, 2005 | 06:47 PM
J BODY's Avatar
I see this on poorly or incorrectly maintained rear differentials with the sure grip. Clutches will "grab" on tight cornering.
Old Sep 3, 2005 | 11:18 PM
WildBill's Avatar
I was thinking same thing, if rear diff. needs service or has been serviced without limited slip additive, it will chatter on slight turns. Use two bottles of the additive.
Old Sep 4, 2005 | 07:47 AM
Geico266's Avatar
Agree. If you are having a shutter when turning it's not the tranny. Its the read differential. Been there done that. Change out the fluid and add the limited slip additive. Go to a parking lot and do figure 8's for 30 mins. Should be okay in 500 miles or so, unless you have damaged the clutches. (unlikely)
Old Sep 4, 2005 | 11:34 PM
coiler33's Avatar
Great call boys. That was my guess but three other simpletons in my truck said its the cheap dodge tranny. Well changed out diff lube and fixed. Thanks again. The other three drive dmaxs which can't keep up with my old dodge but they needed something to make them feel better.
Rafter B
Apr 13, 2008 09:40 AM
rustybudweiser
May 8, 2007 02:07 PM
joel
Jan 7, 2003 10:18 AM
heavyhauler2
33
Dec 26, 2002 07:41 PM
bigbaddiesel
Nov 30, 2002 01:03 PM
