Killed by dowell pin
Old Feb 24, 2006 | 11:02 PM
olsenam's Avatar
Today when my brother was pulling into the jobsite I noticed alot of oil dripping from the front of his 97 12v. Popped the hood and after a minute of looking around I noticed that his timing case was split and spitting oil. (all over me as a matter of fact) His KDP went, and I hated to do it but I told him so. Now he needs me, cause I got a computer, to find out where to get the best deal on a new timing case and maybe some step by step instructions on fixing the problem. Can any one point me in the right direction to find detailed information on this repair. I need him to pull the skidsteer to a job on Wed and his truck is down. Can this repair be done that quickly?
Old Feb 25, 2006 | 12:45 AM
doznfire's Avatar
Not an easy fix by any means.I don't think they give away the gear housings either.Got to pull the cam too.Cummins here in california quoted me around 1500 bucks just to fix the gasket behind the housing. Good luck,someone here with more knowledge will chime in soon..
Old Feb 25, 2006 | 01:02 AM
texaspower19's Avatar
i know they make a kit because its so common
Old Feb 25, 2006 | 09:12 AM
infidel's Avatar
Kits are made to prevent the problem, not to fix it after it happens.
Buy parts from Cummins, unless you can find a used one your only other choice is the dealer. Unless there is gear damage the only parts you will need are the case, gaskets, front seal and a new dowel pin.
Heres what's involved in the repair http://www.flex.net/~triplem/new/dowelpin.htm
Old Feb 25, 2006 | 09:21 AM
mikmaze's Avatar
good gawd, if the link to the repair doesn't make you go get the prevent kit right away and install it instantly then sheesh, you can't be helped.looks like a long day for your and your brother, save the cold ones till the job is finished, ya might mess up more than is already fubar otherwise..........
Old Feb 25, 2006 | 12:30 PM
phox_mulder's Avatar
Where in Utah are you located?
There might be a shop that can get you up and running quickly.
phox
Old Feb 25, 2006 | 07:48 PM
TonyB's Avatar
What year trucks/motors are affected by this?
I've got my '06 3500 on order, due to ship 2/28....Should I be concerned?
TIA
Tony
Old Feb 25, 2006 | 07:50 PM
need12v's Avatar
As long as the cover isn't in too many pieces and you have those pieces, and if there are no gears FUBAR'ed, you can do like we did on my buddy's 97. took the front cover off and looked at all the gears to make sure there was no screwy things going on, then we JB welded the cover back together, put a new gasket and seal on the crank, and it works like a dream! might want to change the oil soon after just in case you drop some gasket in the pan or something.
Old Feb 25, 2006 | 07:54 PM
Geico266's Avatar
TIA
Tony
Up until late 98 is all. You are good to go.
Old Feb 25, 2006 | 08:08 PM
i know they make a repair kit that comes with every thing u need to fix it . i know a guy who got his fixed at texas diesel power
Old Feb 25, 2006 | 08:36 PM
TonyB's Avatar
Geico266, thanks! I appreciate the fast response!
Tony
Old Feb 25, 2006 | 09:52 PM
99 cummins's Avatar
Geico, there you go again tryin to stir it up. Are we gonna have to go there again.
Old Feb 26, 2006 | 12:56 AM
olsenam's Avatar
Im located in northern utah (logan). Just need a step by step instruction as well as a cheap parts source. thanks. A
Old Feb 26, 2006 | 01:01 AM
this should help some http://www.flex.net/%7Etriplem/new/dowelpin.htm
Old Feb 26, 2006 | 01:05 AM
maybe this too
http://www.tstproducts.com/browsepro...epair-Kit.html
