just stopped running
well driving down the road and she just quit running.(217000 miles) i mite have ran it out of fuel but i put 5 gal in it and still not starting.do i have to bleed the injectors to get it to run?? i have fuel and pressure at the filter.whats the procedure to bleed the lines? what a night , the wife came to get me and the 2010 dodge mini van quit at the gas station. pulled the batt cable off and got it to start , back to the dealer tomorrow!! anyway can some one email me and ill check it tommorrow. how do i check codes also? email me at par12730@sbcglobal.net thanks phil
What year?
If it is a common rail, DO NOT attempt to bleed the injectors. It is very dangerous, and the system is self bleeding.
Codes:
https://www.dieseltruckresource.com/...s-t224833.html
Codes:
its a 1999 . sorry alot going right now. just got a call and my dad is in the hospital in florida so i got to get this thing going.i did see a things on codes im going to try this. but like i said i think i may have ran it out of fuel. so in a 99 do you have to bleed them .?? if so how do i do it .i just need to trouble shoot so i can get this thing going to get down south.i'll check back later thanks phil
I don't know if you can pull codes with a 99 and the key trick.
To bleed the system, crack the fuel line going into the VP44, and turn the key on. The fuel pump will run for 30-45 seconds. If you do not see fuel coming out of the line, bump the starter ( motor turns over once, do not start). Repeat this up to three times. If you are still not getting fuel, you need to check your lift pump.
Once you do start getting fuel, with the fuel still flowing, tighten the line.
Check out pg 15 and 16 on this PDF... it's an edge installation manual...
http://www.edgeproducts.com/product_...on_pdf-378.pdf
Cummins Guru
Can you hear your fuel pump running when you just bump the starter? If not most likely transfer pump is bad. If you hear it running then crack the fuel return line (19mm wrench) at the injection pump. That's the line to the front of injection pump. Bump starter until you see fuel coming out fitting. You don't need to crank engine to get pump to run. Just turn key off and then bump starter motor again after pump times out. Tighten up this line, then crack open injector line #1 #3 #4. Crank engine until you start to see fuel here. Crank only 30 seconds max then wait a few minutes to give starter time to cool off. Tighten lines as fuel appears at each fitting. Good Luck.
Tingram
Oct 12, 2008 11:24 PM
BRUISER
Nov 6, 2007 07:39 AM
