Juice/Attitude Code 1693
Old Oct 30, 2006 | 11:29 AM
Kevin B's Avatar
Not sure if this is the right area to post this in but I was hoping for some "techie" replys. I have a Juice with Attitude monitor and the turbo timer has been set on one minute. Last friday while on a job I turned it off and walked away. I came back about 35 minutes later and the truck was still running. At that point I tried many times to shut it off and then decided to just leave it running in case it would not re-start. It ran like crap all the way back to the yard (under powewed) but no codes. Back at the yard I pulled the #9 fuse tap and it shut right off. Unplugged the juice and it ran fine but I got a CEL. Re-attached the Juice box and everything was back to normal, even the CEL light went out. The code is still stored and shows up with the odometer trick.
My question is this, from the reading I have done on codes this seems to be a companion code. Do I need to worry about this or was it just a computer glitch in the box ??
Thanks, Kevin.
Old Oct 30, 2006 | 02:38 PM
Kevin B's Avatar
I don't know if this helps but I just scanned my truck and got a P0237-Boost sensor circuit low-
*crickets* Anyone *crickets*
Old Oct 30, 2006 | 05:24 PM
blackdiesel's Avatar
Registered
the map sensor through that code, not much to concern you with, it will clear it self after so long, if it don't throw it agian. You could check the plug on it, besure its together good
Old Oct 30, 2006 | 07:57 PM
Kevin B's Avatar
Thanks Blackdiesel, CEL light is off and all seems well. Thanks for pinning it down.
Old Oct 31, 2006 | 11:58 AM
Kevin B's Avatar
Is there any danger or reason why I shouldnt erase the code from the computer?
Old Nov 1, 2006 | 10:29 AM
redstreak's Avatar
No worries. Keep on smokin.
5.0 Mustang Man
Oct 21, 2008 02:50 PM
1 Bad '02 HO
Jan 20, 2008 06:21 PM
Gene007
May 16, 2004 05:55 PM
j
Mar 9, 2004 11:45 AM
roadrat
Jan 18, 2004 03:07 PM
