istalling edge comp..
Old Jun 23, 2007 | 06:30 PM
H2SRDMB's Avatar
had a question, where the is best place to put the ground lug.. just wondering! my computer wont open the doc with the directions in it. im not taping the i/p wire, maybe tomarrow.
hopfully i can get the direction to work. but if not im kinda screwed!
thanks a bunch!
bryan
was thinking. the ground on top of the intake?
Old Jun 23, 2007 | 11:25 PM
johnh's Avatar
i grounded mine under a bolt on the air heater intake ( top of intake)
Old Jun 24, 2007 | 04:40 AM
H2SRDMB's Avatar
awsome. thats where i ended up putting it. i could not wait any longer,figured it had aground there allready! but was worried about feedback from the grid heater being right there! runs great. and if it works for you then it must be good.
thanks!
Old Jun 24, 2007 | 07:17 AM
CTD2001's Avatar
Dont ground it there, i had it grounded to the battery, that is why the ground wire is longer then normal. I had it grounded to the intake way back when i first had it and it interfered with the grid heater, not sure what it was doing but the grid heater was getting hot when the truck was not running
Old Jun 24, 2007 | 09:05 AM
johnh's Avatar
i've had no problems untill i sent the box in to edge to have the latest version installed...... now when i start the engine, the box won't turn on untill i cycle the ign switch
they suggested i had a bad ground, so i checked it with my multi meter. it checked perfect
lvmknsmoke..
Nov 21, 2024 07:33 PM
Sthil
Dec 6, 2011 05:18 PM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
