Installed new lift pump...
there are always exceptions, not everybody lives to be 70 either
I am talking about the alen head bolt that is just below the banjo bolt and toward the front of the truck. I do have an electric guage and it was just put in about two weeks ago. I think I will soon upgrade but for now I think I had better spend my money on a Fass or I might install a holley black that I have laying around along with a big line kit.
I had same symptoms as you when I changed the lift pump. Pressure seemed ok, then dropped to zero when I got on it. Turns out that when I tightened the flexible line that provides fuel to the pump, I put a slight kink in it. Worked ok at low demand, but at higher revs the suction from the pump would collapse the line and I'd end up with 0 PSI. Fixed it and all was good. Until, that is, I got a bad load of diesel in Guernsey Wyo. Plugged the filter. Resulted in similar symptoms. Took it easy for a bit, then changed the filter when I filled up next. Seems to have done the trick.
mishkaya
95black2615
Jul 24, 2010 06:21 PM
Fishcop
Sep 30, 2007 11:06 AM
S.Dodge
15
Mar 15, 2007 07:55 PM
