Injection Pump issues?
Old Oct 6, 2006 | 12:26 AM
West Coast's Avatar
timing
Thanks for the replys guys. I found a local "Hot Rod" diesel shop, Screaming Diesel located in my town that is going to take a look at my timing. The owner heard my truck today and imediately said it was the timing. I also called Piers today and talked with Mark. Marked also said after all I have been through and the way the truck is running he also bets it is the timing.
Truck idles at 800 and does not move. I have checked the fuel shutoff valve and wires, everyting looks good.
So here is my issue......
The owner said the timing is no big deal. 1.5 - 2.0 hours total. But said the only issue he might run into is if the pumps tapered shaft has been damaged from sliping and might not be able to retighten. He mentioned is does not happen a lot. How many people in here have had a 12 valve jump timing and ruin the pump shaft???
Thanks......
Dave
Reno, Nevada.....
Old Oct 6, 2006 | 07:03 PM
West Coast's Avatar
Issue Found
Lock washer on pump shaft was MIA. Timing had slipped. I sent pump out to have it checked. Hopefuly pump comes back in good shape.
Dave
tommurray
Feb 23, 2014 10:38 AM
d0d0
Feb 4, 2009 09:45 AM
xyz12383318
Jun 6, 2007 06:45 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
