I took it off road......whoops!
Old Apr 14, 2004 | 08:45 PM
tanderson2002us's Avatar
From: Newman Lake, WA (But my home is deep in the heart of Texas!)
O.k…..so I took her off road….see “My Pics” to assess the mud…………
Two weeks later, 5 trips to the car wash, a hundred .25s later I still have a terrible squeak…………
So I see that the front springs still have mud packed in them, I spray them down again, soak every possible joint, bushing etc. with silicon spray and drive off from the car wash……….now it sounds (the squeak) worse than ever….hit a small bump, and it sounds like the brake pad wear sensors (Squeak, Squeak Squeak) but the brakes are fine…………next I am coasting down a hill and kill the engine in “N” …yes “something” is squeaking…..front wheel bearings? Maybe….I thought they were sealed……..it is enough to drive me ……….
A. Nuts trying to figure it out.
B. Straight to Dodge and say………..something squeaks!!!!!!!! I have 5k left on my warranty…..FIX IT!
Old Apr 14, 2004 | 09:13 PM
whazzup's Avatar
Every once in a while I will get a small rock caught betwwen the pad and the rotor. I have never had one work its way out. When going thru wet sand or mud I try to keep the brakes applied just a bit to help keep the junk out.
Good luck this type of thing makes me want to ride the Huffy Davidson again.
Old Apr 14, 2004 | 09:15 PM
quantrill88's Avatar
Im in the exact same situation you are. Cleaned off almost all the mud from under the truck and Im still getting a squeak.
Never really considered the wheelbearings since the squeak sounds like the shifter linkage noise I had before.
Crap . I still have warranty left but really dont want to take it to a dealer.
anyone else experience this?
Jeff
Old Apr 14, 2004 | 09:37 PM
SuperSonic's Avatar
My truck had the same (squeak squeak squeak) just recently. Turned out to be bad rear U joints. Now i'm ridin squeak free.
Old Apr 14, 2004 | 09:44 PM
ill check the ujoints but I really dont think its them. squeak seems to be coming from the frontend.
Old Apr 14, 2004 | 10:04 PM
I guess the 1000K $ questions are .....(and thanx for everybodies replies.....sorry for the urinal attitude).....
1. If I get muddy and spray the truck and belly down....could I wash my front bearings dry??????? I have sprayed the rotors etc. about 5x now............
2. Will my Bumper to Bumper warranty cover "washing the truck" in the event that something has been degreased?
Tom
Old Apr 14, 2004 | 11:08 PM
wagontrain131's Avatar
I've had the same problem with my rig before. Sounds like something in the brakes. I usually goes away.
Old Apr 14, 2004 | 11:31 PM
jaconst's Avatar
you do have u-joints in the front axle also from transaxle to front diff I had squeak in front end in both my 95 ctd and 2001 1500 gasser and it was u joint in the front axle right behind the spindle assembly or behind rotor and bearing on front shaft. good luck
Old Apr 19, 2004 | 11:44 AM
James Andres's Avatar
Check the dust shield on the front rotors. I have had one that appeared fine. Jacked it up and no noise when spun by hand. Noise was slightly worse while making a turn. Tweeked it away from the rotor and it stopped.
Old Apr 19, 2004 | 02:59 PM
BigBlue's Avatar
I've had a squeek in my front end for a long time now. I have never been able to figure out where it is. Only thing that helped was when I sprayed the steering shaft INSIDE the truck with silicone. That helped solve it temporarily. I took it to Dodge but they blamed it on my leveling kit and wouldn't fix it under warranty.
Old Apr 19, 2004 | 03:38 PM
uncleroty's Avatar
For my two cents I'd check the brakes for material caught in them, the dust shield as james said above, or possibly the front pinion. If sand/mud gets in there before the seal, it makes a sort of high frequency repeated squeek. A shot of lithium grease in the area will solve it if that's the problem. This happens on jeep dana 35's constantly, and may be the problem on your truck.
Good luck with it.
Old Apr 19, 2004 | 03:49 PM
Mcmopar's Avatar
Smile
Glad to see someone else who gets their truck very dirty, my little boy loves to 4 wheel. Most guys I see don't know how to put it in 4 wheel drive.
Old Apr 19, 2004 | 03:52 PM
uncleroty's Avatar
Amen to that !!!!
Old Apr 19, 2004 | 08:44 PM
checked my brakes, seem ok.........
cant figure it out.......seems exactly like the transmission linkage squeak Ive had before except this time, no amount of PB Blast can cure it
bandit1trucking
Feb 14, 2019 08:16 AM
Onemoparnut
Aug 17, 2008 09:39 PM
greasy
Dec 16, 2004 02:52 PM
Swamp_Donkey
May 14, 2003 09:31 AM
Mule Skinner
Nov 16, 2002 06:57 PM
