i need a pump
i need a pump
i thught i fixed my pump the throttle shaftseal. i also stuck a 3200 gov spring in it then igot it all back together and the pump return line broke. then i got all that fixed and put 80 dollars in the tank. everything looked fine no drips anywhere. so i drive it from my shop to home. its about 11 miles. i get home and open the hood and it is driping from the throttle shaft seal again. i am never going to drive my truck. i need to know where i can get a pump that i don't have sell a nut for bot is a good pump. thanks guys i am so ******
If the throttle shaft bore is worn, a new seal often won't correct the leak... you might need to bush the bore and then install the new seal.
Don't forget to check the throttle shaft itself for wear in the seal area.
it looks like it is leaking from everywhere. the spring on the throttle shaft is full of fuel. fuel is mostly running down and dripping of the manual shut off lever. i am sick of this i just want my truck to run with out leaking fuel. i have been dealing with this for about 2 mouths
Good - the best way to repair a problem is to observe it happening...
Thoroughly clean/dry the fluid from the engine and surroundings.
Start the truck (maybe a helper can do this) and immediately watch for where the diesel is leaking from first - drips, sprays, moisture or whatever.
Once you located the problem, fix as needed.
Let us know what you find...
You could try looking at some of these sites to see what they offer: https://www.dieseltruckresource.com/...gh-Performance
wwm
Feb 26, 2009 08:37 PM
89dieselkong
Dec 18, 2007 11:38 PM
wana12v
Sep 5, 2006 05:19 AM
adgr71
Nov 28, 2005 07:34 PM
TPilaske
16
Nov 22, 2002 08:15 PM
