I feel dumb asking but???????
Old May 18, 2007 | 02:06 PM
smokeum99ta's Avatar
It time for an oil change and I can't get off the drain plug. The previous onwer rounded it off. I think it a 3/8 allen wrench but not sure because it has no edges now. Any ideas? I've tried several different ways to remove it but am out of ideas. I didn't try to heat it up with a torch because it didn't seem like a good idea. Thank for any help. Ken
Old May 18, 2007 | 02:32 PM
mx684's Avatar
I have seen this happen before, i weld nuts onto the plug then u can get a socket or wrench and break it loose..
Old May 18, 2007 | 03:09 PM
vzdude's Avatar
DTR's 'Go to Guy'
Or you can turn it out with a chisel. Either way, make sure to have a new one on hand!
Old May 18, 2007 | 03:14 PM
PaulDaisy's Avatar
The plug has a 3/8" square hole. It may be rounded out on the outside, yet still have some flats to catch on deeper. Try a regular 3/8" square breaker bar, maybe it will work.
-P
Old May 18, 2007 | 03:40 PM
Dr. Evil's Avatar
14"-18" pipewrench.
Of course you will have to replace it. Get something better than stock. Genosgarage has a HD drainplug as well as a couple of different qucikdrain plugs. Fram makes a quickdrain plug as well.
Old May 18, 2007 | 03:42 PM
I'll try the 3/8 square end first. I hope that works becuase I might have aided in rounding it off. Then weld the nut on if that doesn't work. If that happens where is a good place to get a new drain plug?
Old May 18, 2007 | 03:51 PM
Dr. Evil's Avatar
Already posted.....
http://www.genosgarage.com/products.asp?dept=24
Old May 18, 2007 | 04:13 PM
BIGBADBOB's Avatar
I have the EZ-Change and it works slick. No mess just point the hose in a pail and it over. My old plug had the washer seperate from the threads.
Old May 18, 2007 | 06:49 PM
Thanks everyone. I got it with a regular 3/8 drive rachet and short extention.
Aquah0lic
Jul 29, 2011 11:15 AM
schamran
Apr 11, 2009 05:32 PM
smokeum99ta
Jul 21, 2007 11:41 AM
triton0708
Aug 19, 2006 03:09 AM
Dave88LX
Jul 5, 2005 05:32 PM
