I Broke My Ve Pump
I Broke My Ve Pump
with my fuel problem still not solved i decied to put in my 366 spring , did all right, was thighting down the pump top when i heard a snap like i had broken a bolt off in the housing , so i backed them off and none of the bolts were broken, i poked around and found in the top back corner the top of the fuel lever [i think] had broken off , i thinking i will have to pull the pump to fix it, anybody have this happen? how did ya fix it?
You broke the governor lever. You tried to do it without pulling out the fuel screw, didn't you?
Fix is to get a new governor lever. The sticky on the 1st gen board has an exploded diagram with the Bosch part numbers.
so i backed it out ,looks like i didnt get it out far enough
thanks Dave ,oh by the way i found out way my fuel screw went in only two an half turns ,the shoulder on the screw was right to the threads on the pump top
WARNING dont break the fulcrum lever that bunch of levers only comes as one peice unit an its$418.18
thank goodness the local diesel pump guy has some industrial pumps ,i'v pulled my pump i'm headin to his shop tomarrow to compare pumps THANK YOU DAVE for putting up with me
smokeum99ta
Dec 8, 2017 01:32 AM
4969joes
Mar 28, 2010 05:26 PM
4969joes
Mar 27, 2010 08:58 AM
