Hydro Booster???
Old Aug 18, 2005 | 11:02 AM
G-NOTE's Avatar
Exclamation Hydro Booster???
I don't know for sure but something is causing vacum pump to break gears...
Maybe a bad hydro booster pressure locking and not realesing, or steering gear box???
Something is applying pressure and breaking the gears!!!
IN Serious need of help!!!
Old Aug 18, 2005 | 12:29 PM
G-NOTE's Avatar
Would the ABS controller (cab unit ) not being programmed cause this problem???
Old Aug 19, 2005 | 04:56 PM
G-NOTE's Avatar
NOTHING???
Old Aug 19, 2005 | 10:47 PM
DODGE 92's Avatar
id like to help you but
Old Aug 20, 2005 | 08:12 AM
Mopar1973man's Avatar
Bad power steering pump???
Old Aug 20, 2005 | 08:18 PM
Dualler's Avatar
I would say either the PS or vac pump is seizing up. I would not think it is a hydrobooster or PS box problem as the PS pump has an internal pressure relief. Did you check the other gears for damage and/or wear too? Is the pump assembly mounted tight and square to the housing? If you end up needing the PS/vac pump assembly including the gear, I got a good used unit.
Old Aug 22, 2005 | 07:29 AM
G-NOTE's Avatar
I appreciate the help guys, I think were going to swap out the motor. I bought a "55" block , so were going for the swap instead changing gears and flushing the motor...
Old Aug 23, 2005 | 08:09 PM
Dualler's Avatar
If you have not swaped the motor yet, I would also check the harmonic balancer. Bad harmonic balancers on diesels can snap the balancer or flywheel bolts and it is not hard to immagine that it could damage the gears too! As ar as getting the metal out of the engine, the large chunks probably won't hurt anything. They just sit at the bottom of the oil pan and would not make it past the pump pick up tube screen anyway. I would just drop the oil pan if you want the stuff out anyway which is much easier than pulling the whole engine. When the pan is off I would check a couple of crank and rod bearings and if everything looks OK you should be good to go.
cmcr0703
Oct 9, 2015 09:32 AM
yfz450guy
Mar 9, 2015 12:27 PM
Boner
26
Dec 5, 2004 03:49 PM
Holycack
Nov 9, 2004 12:21 PM
ironman
Sep 2, 2004 08:36 PM
