hurricane under my hood!
Old Jan 15, 2007 | 08:20 PM
six speed's Avatar
I owne a 2001 ram 2500 w/six speed man.
When ever I try to get on the throttle I hear a lot of air loss noise.
It's blown the insullation off the inder side of my hood but I can' find a leak anywhere. Can any one help?
Old Jan 15, 2007 | 08:45 PM
FMB's Avatar
FMB
Well first off, welcome to DTR. Go up to the dark bar up above and click on "User CP", find the "Edit Signature" link in the left column and make a signature. Tell us what you have with your '01 2500 6sp.
Get under the hood and check the boot from the turbo to the intercooler, all over the intercooler, and the boot from the intercooler to the intake manifold. Something is either loose, cracked or split.
Old Jan 15, 2007 | 08:48 PM
Quad59's Avatar
Where exactly is your insulation torn, what is directly below or around this area? Turbo, charge air tubes, intake plenum. Look for loose or broken clamps on all the charge air plumbing.
Old Jan 15, 2007 | 10:58 PM
Sidewinder's Avatar
If it is a boost leak it will be hard to find unless the truck is under load so the turbo is making boost. Try doing a search and you should find lots of help to find a boost leak. Do you happen to have a boost pressure guage on your truck?
Old Jan 15, 2007 | 11:26 PM
XLR8R's Avatar
Could you fill out your sig, please?
Old Jan 19, 2007 | 09:00 PM
six speed's Avatar
right above the fan cowling...I've checked the fan clutch and it's ok.
Old Jan 21, 2007 | 05:54 PM
six speed's Avatar
Hey guys, Thanks for the help.
I found the leak, It was in the boot coming out of cooler. I made a couple of boot caps. Onne blank and one with an air "qwick connect" with a 8 lb kunkle valve. I started to pressure it up and the crack became evident big time!! * lbs doesnt seem like a lot but it realy is. Thanks for all your help you guys are great..
*2001 Dodge ram
*4x4 six speed trans.
*cummins 5.9 turbo diesel
*254000 miles and still going strong
Dougk
Jan 30, 2010 12:11 PM
Eddy Reyes
18
Jun 28, 2007 12:06 PM
Dodgezilla
Feb 13, 2004 03:40 PM
JKE
Sep 23, 2003 05:58 AM
Mostwanted
Jul 15, 2003 02:22 PM
