hung up on rotor removal!!!
Old May 10, 2007 | 04:41 PM
airplaneman00's Avatar
I need some help here. Decided to go with a front brake job, rotors were trashed. I cant get that freaking nut off of the axle if my life depended on it. Whats the deal? are they reverse thread, or torqued on by godzilla?!!?!?! anyone got any experience here.? Its a 99 4x4 2500.. thanks. Im stuck and missing work
Old May 10, 2007 | 04:57 PM
John Faughn's Avatar
If my memory works I think the torqu. spoc. 180 ft. lbs.
It seems that it can take double that + to get off , then it also depends on the last one that put the nut back on .
A good !!! 1/2 " impact is required to get loose .
I've tried a 3' snap on 1/2 breaker bar with a floor jack hand - it weighed 10 lbs. so it wasn't a lite weight , that would break it lose .
Old May 10, 2007 | 06:52 PM
infidel's Avatar
Beware of using too much torque to try and remove the nut. Many times the nut is galled to the axle threads because no antiseize was used. If you have to resort to a 4' cheater bar you are likely to take the threads
right off the axle end = $$$.
Heat the nut or split it to remove.
Old May 11, 2007 | 08:29 AM
well we finally got one of them off. a little heat and a nice whack from a sledge on a cheater got it off. anti seaze here we come
Snoxracer
15
Mar 11, 2008 09:44 PM
NOSTROKER
Feb 20, 2008 10:26 PM
shudabo
Dec 11, 2007 11:34 AM
RenegadeT
Nov 2, 2006 12:22 PM
Buckshotram
Oct 29, 2006 10:13 PM
