How do I get this injector out ?
Old Apr 21, 2009 | 04:51 PM
Checkmate's Avatar
I'm trying to pull out my #6 injector because it's having issues. :-)
Anyway, I've got the fuel line pulled, got the hold down removed and can't seem to be able to pull this thing out. I don't wanna break anything. What's the trick. (besides the "tool")
Also, once I get it out, what should I LOOK for as the cause of my stuck injector problem? Can you tell by eye?
Thanks, Dan
Old Apr 21, 2009 | 05:38 PM
patdaly's Avatar
Piece of PVC pipe, cut to length ( not sure how long) and a lug nut off of your truck. It is the redneck Injector puller.......
Not sure how to tell if it is stuck though.
Old Apr 21, 2009 | 06:45 PM
Here's a how-to on making an injector puller.
https://www.dieseltruckresource.com/...d.php?t=124728
Old Apr 21, 2009 | 07:00 PM
infidel's Avatar
1-3/8" length of 3/4" steel or PVC pipe, one lug nut and washers if needed.
Just slip the pipe over the injector and screw the lug nut down.
Most times you don't even need a wrench to pop them loose.
Old Apr 21, 2009 | 07:29 PM
Checkmate's Avatar
Okay guys. I should have specified that this is on my 03. Totally different injectors.
I WISH they were that easy. :-(
I checked in at another site and found a whole set of instructions on pdf.
Old Apr 22, 2009 | 11:53 AM
~Angry Tractor~'s Avatar
Can you bar the engine over and let the compression push it out?
Old Apr 22, 2009 | 08:26 PM
rich's Avatar
you did remove the injector tube, i usaully get them to pop out with a screwdriver and a set of waterpump pliers sometimes they are little hard to pull out
Old Apr 22, 2009 | 08:36 PM
Hvytrkmech's Avatar
Where you pulled the feed line to the head, there is tube that mates to the injector to deliver fuel. You need to pull the feed tube to pull the injector. Once the tube is removed then a gentle pry is all you will need to pull the injector.
Also once you pull the injector out make sure the copper sealing washer came out with it.
Tim
Old Apr 22, 2009 | 08:50 PM
Checkmate's Avatar
got the tube out, but I can't get the injector out. It's the number 6 so it's a real bear to try and get to.
What are water pump pliers ?
Old Apr 22, 2009 | 09:43 PM
rich's Avatar
they are the large adjustible pliers. it shouldnt be too hard to get out twist it back and forth some
Old Apr 23, 2009 | 09:56 AM
infidel's Avatar
They're also called Channellocks
Old Apr 23, 2009 | 10:13 AM
Checkmate's Avatar
O channel locks :-) I get it now.. Is it okay to twist the injector ? I was afraid to mess something up.
Old Apr 23, 2009 | 07:17 PM
rich's Avatar
you can turn it some i usaully grip with the pliers and try to pry up or pop it up the plastic on top is the only fragile part
Old Apr 23, 2009 | 08:15 PM
Checkmate's Avatar
Cool, I'll try that. Thanks
getarealjob
Aug 21, 2006 07:31 PM
kawi600
Jan 26, 2006 10:19 AM
G-NOTE
Sep 1, 2005 06:36 PM
oscaroc
Apr 2, 2005 12:14 PM
