High idle controller
Old Feb 14, 2006 | 06:22 PM
mooseman's Avatar
A couple weeks ago I found a high idle kit on a manufactures site. Now i cant remember the site where i found it.
Can someone help refresh my bad memory and tell me who makes/sells this kit?
Thanks in advance, Mooseman
Old Feb 15, 2006 | 01:16 PM
spitfire9137's Avatar
Do you have cruise control? If so why buy the kit, just go to the dealer and get them to do a reflash.
http://dodgeram.info/tsb/2001/18-019-01.htm
Old Feb 15, 2006 | 03:00 PM
Lil Dog's Avatar
2001 will only have the cold start upgrade with the 3 cylinder mode and auto up idle under 60°F manifold temp.. I think mooseman wants a variable control idle..
This is the one I know about. http://www.psdieselproducts.com
Old Feb 15, 2006 | 04:22 PM
JKM's Avatar
JKM
The dealer can enable an option in the PCM/ECM that allows the cruise control to act as a variable high idle.
Old Feb 15, 2006 | 05:09 PM
CTD NUT's Avatar
That is the cold weather high idle TSB and does not work in conjunction with the cruise control.
Do you have any more info on this? A link or a TSB # or something? I have never heard of this.....I would like to know how to get it done. I will have to be able to hold the dealer tech's hand to do a reflash around here!
Old Feb 15, 2006 | 05:14 PM
JKM's Avatar
JKM
Phox Mulder knows alot more about it than i do , try pming him.
Old Feb 15, 2006 | 06:13 PM
phox_mulder's Avatar
Only the 3rd gens have the cruise control activated high idle.
2nd gens only get the temperature controlled high idle.
phox
Old Feb 16, 2006 | 08:44 AM
CTD NUT's Avatar
Ok, thanks....that is what I thought.
Old Feb 19, 2006 | 02:17 PM
Katmandu's Avatar
Question
What RPM are 2nd Gens "supposed" to do the High idle at ??
Old Feb 19, 2006 | 02:40 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Or just use the Home Depot High Idler kit.
It works in all temperatures, costs much less, and doubles as an attitude adjuster.
Old Feb 19, 2006 | 02:46 PM
Katmandu's Avatar
Question
LMAO~! How do you Calibrate that thing ??
Where do you set the High Idle RPMs at ??
Old Feb 19, 2006 | 03:06 PM
signature600's Avatar
Power seat works good for me!!
12-1300 RPM usually!
HTH,
Chris
Old Feb 19, 2006 | 03:07 PM
infidel's Avatar
I use the power seat to adjust my Home Depot High Idler.
My high idler also doubles as an ice scraper.
Old Feb 19, 2006 | 05:19 PM
Between 1,000 and 1,200 usually.
phox
Old Feb 19, 2006 | 07:24 PM
Shovelhead's Avatar
Mine is "calibrated" for 1200 rpm.
Just trim until you get it where you want it.
