Help with truck starting
Old Dec 3, 2006 | 09:13 PM
joeel's Avatar
Unhappy Someone must have an ideal. Won't start in cold weather until warmed up.
[/B][/B]My 2003 is giving me fits when the temp drops outside. It has always been a little slow to start, but now will not start when temp below 40. Grid heater is working good(burnt my hand on manifold after cycling a few times). Lift pump sounds strong. Truck runs well after start. The fuel heater has 11 volts to it. I cannot tell if it is getting warm, but should it matter at 40deg? The fuel does not gel until lower. Could it be the fuel control actuator not opening properly. I have replaced the lift pump with new one from cummins last spring. I can plug it in and let it warm up for 10 minutes and it starts fine. Fuel filters were replaced right off the bat. Old one looked clean.
As a side note could overdue valve adjustments make it harder to start?
Is there a thermostat on the fuel heater? I see the connection below the heater that I believe is the water in fuel.
Hope my questions don't jump around too much. This is frustrating.
I edited this request because I have not gotten any replies. Someone must have an idea about the fuel heater thermostat and the other questions????
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
CRYSTALCRYSTAL
Jun 4, 2008 05:23 PM
abc4yew
Mar 15, 2007 11:55 PM
running4bhs
Apr 10, 2006 07:56 PM
