Help with trailer lights on 03
Old Feb 6, 2008 | 04:45 PM
Hot Rod 4's Avatar
I have no left turn signals or brake lights at my trailer connector I have traced the wire to a connector under the floorboard and have no power. The only other connection is at the fuse block. I can hear the relay clicking but they are not working. I would like any suggestions if anyone else has had this problem. and yes the fuse is good. the only other thing that i can think of is the relay which is contained within the fuse block which is 400 bones. so any ideas?
Old Feb 7, 2008 | 01:40 AM
bandit1trucking's Avatar
On the '03 3500, there are individual fuses for each trailer turn signal, and I beleive each side trailer brake light. can't remember about the brake lights, but I was really upset after re-wiring the whole back end of one of the tandem dual trailers when we first got the truck, only to find out it was just fuses. I don't know if the 2500 is the same way, but I'd check closely.
Old Mar 2, 2008 | 04:22 PM
klx300guy8's Avatar
You got it, its the fuse box just had mine replaced yesterday, $425.00. All I know is I'm going to spend some time looking over my trailer to find the short that caused it.
Old Mar 3, 2008 | 09:51 AM
Hot Rod 4's Avatar
I have not had time to look into it lately just pulled the trailer as it was, didn't get pulled over. I am going to look into wiring in external relays to hopefully solve the problem. If I do I will do a write up and pics because I have seen a few more people with the same problem. I just have a hard time replacing a $425 part that chrysler has not made any changes to solve the problem. More than likely it will happen again. It should not be to hard just have to find a way to do it that the computer won't throw a fit. 2-$10 relays>$425 part that is a known failure.
JIROBBI
Jul 24, 2007 09:51 PM
KATOOM
Dec 24, 2003 06:54 PM
CHarlan
Aug 6, 2003 08:40 PM
