Help Please!
It could be anything , including chicken little falling from the sky .
The point being , testing is how to fix things , guess what to test after a good description of symptoms .
Just because you get a code number does not mean that is what is wrong , a code is where the computer program is picking up an anomaly [ something that the computer see's that does not make sense to it ] .
That is just where you start testing .
You should also tell where your at , you may find that a member is in your area and willing to help .
With the noise & performance issue , possibly a intake boot popped off , has anything been done to it recently ?
Pull a fuel sample yet? Ya never know till you look.
Lift pump putting out any volume? That can be done for as cheap as looking at the fuel.
I'm thinking (yes....stand back this can be dangerous) that a scan tool could be of some importance at this time.
I'm going "all in" and saying he needs a VP!
Anyway, what was the code(s) that were shown.
He threw that pass incomplete on the first post.... Now the "parts guy" wants to sell him a cam sensor.
rattlerbob5.9, you are correct in that any type of air leak will not fix itself. My thinking was along the lines that when "it ran fine for a while" it was not under load during that time and "appeared" to run fine. I'm sure he appreciates all of the information we can send including your input to find the real problem. All we can do is offer whatever information we as individuals feel may be helpful. That is what makes this site so great.
Always start with the basic's and work up from there.
How are you doing these days my friend ?? I am still very happy with what i picked up out your way last year.
You and Mark are always in my thoughts -also great guys and fellow members here.
Please correct me if I'm wrong but if the VP-44 was going out that would mean not getting enough fuel. The black smoke is usually caused by to much fuel to air mixture and not burning completly. When my VP-44 was on it's way out I didn't get excessive black smoke, just the dead pedal syndrom. I can't give any input on the crank/cam sensor since I never had any experience with issues there. I did have a boot blow out and the VP-44 die on my old '99 2500. As stated, start with the simple and easy to check items and work your way through eliminating these first.
MoparRiggan
Jan 17, 2006 12:43 PM
