Help Installing FASS
Old Nov 28, 2007 | 02:41 PM
EverydayDiesel's Avatar
Can someone tell me where to mount the FASS bracket? The directions I have are for an 03-04 (mine is 01) and apparently they are nothing alike.
Old Nov 28, 2007 | 09:26 PM
XLR8R's Avatar
Put it where there's room - usually there's a spot on the frame between the fuel tank and the cab.
Old Nov 29, 2007 | 07:13 AM
fade94's Avatar
I also have an 01'. I installed it on an existing bracket on the bed just in front of the filler tube. You'll have to drill some holes in the bracket and an angle drill works best. I can try to get a pick for you but not sure how it will turn out since I have fender liners on my truck and you can't see the FASS from the rear. Let me know.
Old Nov 29, 2007 | 07:19 AM
I finally found a place to mount it. Hopefully it will work, its very sturdy and out of the way.
Old Nov 29, 2007 | 09:06 AM
yfz450guy's Avatar
i would be more concerned about that spring bolt.
Old Nov 29, 2007 | 09:12 AM
Dr. Evil's Avatar
Ditto......
Old Nov 29, 2007 | 09:15 AM
XLR8R's Avatar
... looks like the iron oxide weld failed!
Old Nov 29, 2007 | 10:08 AM
fade94's Avatar
Looks like a bed bolt is gone also.
Old Nov 29, 2007 | 10:39 AM
Ive been meaning to ask about that spring bolt. That bolt is WAY too long it goes all the way in but I want to replace it soon.
What do I have to do in order for that to happen? Does the leaf spring naturally want to straighten out? or can I just take the bolt out?
Old Nov 29, 2007 | 10:40 AM
fade94's Avatar
Everyday, what part of Dallas are you in?
Old Nov 29, 2007 | 10:51 AM
Lewisville
Old Nov 29, 2007 | 10:56 AM
fade94's Avatar
I'm just up the road North of McKinney. Holler if you need a hand.
Old Nov 29, 2007 | 10:59 AM
Thanks for the offer but I pretty much got everything done now, all I have to do is find a T with a fitting that I can hook up my edges fuel pressure sensor.
razor6
Apr 28, 2006 10:18 PM
lezmark7
Feb 27, 2006 09:37 AM
drew03
Nov 14, 2005 10:20 AM
powerstrokin03
Jul 19, 2005 03:58 PM
gdh11
Aug 31, 2004 07:57 AM
