Help installing clutch as i type.
Old Apr 11, 2008 | 02:47 AM
inline6359's Avatar
I am installing a DD clutch right now can cannot get the first plate off the flywheel right after the disk.
Is there a trick to this?
The truck is a 2006 3500 6spd.
Old Apr 11, 2008 | 06:55 AM
South Bend Clutch's Avatar
Vendor - Former Vendor
Call me, it is easy when you know what to do.
Peter
800-988-4345
Old Apr 11, 2008 | 07:39 AM
PourinDiesel's Avatar
Sounds like you have the dual mass flywheel and need to remove the flywheel from the stub flywheel that connects to the crankshaft.
You have to remove the transmission adapter cover plate which is located on the turbo side of the flywheel housing and remove the bolts similar to the way a torque converter bolts to a flexplate from the inside.
kohldad
Jun 26, 2013 11:52 AM
95black2615
Big Rigs
Feb 6, 2013 06:10 AM
97_Dually
Nov 19, 2009 03:40 PM
Hercules
Nov 5, 2007 05:36 PM
kram
Aug 29, 2007 11:01 AM
