Help!!!! Diesel Leaking!
i have another problem... the hose coming out of the fuel filter is leaking alot of fuel. any ideas on how to stop it from leaking... and why is there a hose for it to drain???
I think Happycap was wondering if you used the drain. Although the good book says to drain the filter bowl at times, unless it's an emergency, I'd never touch mine. The orings set into the drain passages over time and then are subject to tearing when you open the drain ****. The valve assy is available separately, or if you have access to an assortment of orings you can take it apart and "re-ring" it.
FYI I've seen people in "a pinch" thread a screw into the drain hole to stop the leak. Seemed to work.
lilsuzuki4x4
Sep 1, 2011 01:50 AM
STANGGT40
Nov 19, 2010 08:54 PM
Brad4406
Oct 30, 2009 11:25 PM
ouchman
Mar 31, 2004 02:10 AM
