Help
Help
Help,
My truck will not start. This has been an intermittent ongoing problem. My truck is a stock 04.5 except for K&N intake and pacbrake. I have 9psi fuel pressure from the lift pump in the tank, but all it does is crank and crank. Oil level is normal, truck ran fine yesterday. There is one error code, p0477.
Thanks for the reply
I just got it started after reading another thread about an 04.5 and chafed wiring. I moved my steering wheel up and down and it fired right up. I have had a situation now for a little while where my heater/ac fan will not run in the cab. Adjusting the steering wheel up or down ends the problem. I had the cover off the column, and could not find the source of the problem. Could an electric supply issue cause the no start problem? I am out of ideas. Everything about the truck is fine when it is running, no smoke, no surging, no issues at all.
2500TurboDodge
Jul 31, 2006 04:21 PM
