HELP:code P1690, truck running rough
Old Feb 17, 2004 | 09:04 PM
WLDuBard's Avatar
HELP!! I fired my truck up to head home and right after it cranked it started running real rough like it was missing and the engine light also came on. I left and as I was going down the highway it started surging, it almost felt like the trasmission was slipping because power would seem to stop and the motor would seem to rev. I checked the codes and it pulled up P1690. I looked it up but I dont understand it. The truck is stock except for straight exhaust. Would the straight exhaust void the warranty? Should I go ahead and take the truck in to get looked at? Any help would be appreciated.
Old Feb 17, 2004 | 09:48 PM
Borush's Avatar
What year truck? What did it say about the code?
Fill in your signature at the bottom so we know what ya got.
Boyd.
Old Feb 17, 2004 | 10:59 PM
WLDuBard's Avatar
sorry about that. The code was P1690, Fuel Injection pump CKP Sensor does not agree with ECM CKP sensor
Old Feb 17, 2004 | 11:32 PM
Borush's Avatar
It might be a bad crank position sensor.
Old Feb 18, 2004 | 01:29 AM
daystar's Avatar
Same problem , but no OD or Cruise
1998 1/2 OBDII Read the P1690 and and the P0336,also read the P0720 for the speed position sensor in the tranny and the P1689, P1693 codes.
Changed the Crankshaft Position sensor, The Speed sensor in the tranny. Let me back up a minute. I had lock in lock out for awhile on the tranny , OD and cruise always worked, Changed TPS , did'nt help. thats when read codes. Anyway now my rpms are steady, lost Overdrive and cruise ,but trannny and engine run well otherwise. When I read code now , and drive for awile couple days, P1690, P0336 come back ......... Crankshaft Sensor?
Again.
1998 1/2 24 valve automatic, and taking off work to fix this puppy. When I first changed the crank sensor evrything was great for one day then the ovwerdrive went out, thought I had it.
I'm going back to the good ole 12 valve, anyone need a cheap truck?
Old Feb 18, 2004 | 01:38 AM
daystar's Avatar
For Dubard,, The crank sensor seemed to smooth the problem out , I had 8 codes now I have three. P1693, P1690, P03660.
It just didn't figure , I thought it woud have been the P0720.
Cause all I needed was OD back. IF you gcasn get help for your
1690 code , I'll be watching. My first post so thanks for the patience.
Old Feb 18, 2004 | 06:20 PM
daystar's Avatar
Red face code P1690
Say Dubard, I found the code source ,I'm getting same one and makes sense.
P1690...... Fuel Injection Pump CKP sensor does not agree with ECM CKP sensor
I changed my CKP sensor then got these codes: P1693 and then two times P1690
I'll post again maybe we can get some help?
Old Feb 18, 2004 | 07:26 PM
WLDuBard's Avatar
I called the Dodge dealer today and talked to the diesel mechanic and he said it is not the crank position sensor since my tach is working the way it should. He also said my truck does not have a cam position sensor. He said the problem sounds like one of the fuel pumps is starting to go out. I am going to take it in the next day or two to get the fuel pressures read. Also, the truck still idles rough and surges but it has not thrown on the engine light or any more codes.
Tim F
Jul 20, 2016 02:34 PM
LUKE-MM-PULLER
Sep 29, 2013 12:51 PM
rokrawlr
Sep 3, 2010 03:50 PM
Timberman
Jan 20, 2008 07:44 PM
daystar
Feb 25, 2004 02:57 PM
