Help!
Old Nov 25, 2007 | 11:11 PM
Badboy44's Avatar
Help!
So driving Home from Thanksgiving vacation, tachometer goes to 0, then back up. Check engine light on. Keep driving, shut it off a few times, start it, Check engine light goes off but down the road a ways the tach does the same thing. Truck seems to run just fine, got me home the rest of the 150 miles it had to. Did have a "Burp" a couple times cruising at about 60 MPH. I'm hoping it is a sensor going haywire, Seems to have good fuel pressure, I stopped and checked all the connections in the engine bay I could find. Anyone have any Ideas?
Not sure if it would be related or not, but the Oil pressure sending unit went out about two weeks ago, but haven't had a problem since I put the new one in.
Thanks for any help!
Nick.
Old Nov 26, 2007 | 12:23 AM
Totallyrad's Avatar
Just giving you a bump Nick. Were all the battery connections clean?
Old Nov 26, 2007 | 12:26 AM
walt99's Avatar
yea go get codes pulled on it cause everr time mine does it something goes wrong like now i have code P1693 and it wont start and dont know whats wrong
Old Nov 26, 2007 | 08:31 AM
slim51015's Avatar
cam sensor or crank sensor, depending on the year, pull the codes
Old Nov 26, 2007 | 08:48 AM
Badboy44's Avatar
Yeah, battery connections are clean. I don't have a scanner, so I am going to slip down to Napa first thing and see if I can pick one up. From everything I have been reading it is either the crank or Cam sensor, or at least it sounds like it. Thanks for the help guys.
Nick.
Old Nov 26, 2007 | 10:00 AM
Badboy44's Avatar
Pulled codes, 0336- crankshaft pos. sensor, and 1690 not in the list? Any ideas? I'm guessing it is a code as a result of the failing sensor. I'm going to get the sensor changed and see what happens.
Old Nov 26, 2007 | 10:12 AM
slim51015's Avatar
1690-
Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor
Looks like the crank sensor.
Old Nov 26, 2007 | 10:15 AM
scootertrash35's Avatar
if you fill in your sig it might make it easier for members to assist you
Old Nov 26, 2007 | 12:53 PM
Badboy44's Avatar
Changed crank sensor, cleared codes- everything A OK right now. Thankks for your help guys. Scooter- I'll fill in my Sig, sorry about that.
Old Dec 7, 2007 | 11:23 PM
mx572000's Avatar
I kept changing sensors on mine when I had the same symptoms. It ended up being a wire rubbing across the back of the motor. The engine rattle wore a hole in a wire and threw codes for different sensors.
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
