92 Auto speedometer and OD stopped working at the same time
Old Dec 5, 2007 | 11:25 PM
goyduf's Avatar
I made the mistake of letting my younger brother borrow my 92 Auto and the first time I drove it after him I noticed two new problems:
1.) The speedometer does not function.
2.) OD does not engage.
I'm assuming that these two symptoms have a single cause. Has anyone else experienced this and found the solution?
Regards,
goyduf
Old Dec 6, 2007 | 06:21 AM
JD730's Avatar
Most likely cause is the VSS or Vehicle Speed Sensor on the either the tail housing of the trans or the transfer case, depending on 2 or 4 wheel drive. The PCM as simple as it might be needs a few inputs in order to engage OD, 1 is the vehicle speed.
It is either a bad sensor or the little square drive is stripped on it. Pretty much a 50/50 shot on either one being the cause.
Old Dec 6, 2007 | 11:56 AM
Chrisreyn's Avatar
^^^ agreed^^^^ tho hopefully it is somethign as simple as the wiring connector pulled loose....
Old Dec 8, 2007 | 07:40 AM
goyduf's Avatar
Found that the distance sensor has a squared off post that was mostly rounded from wear. Waiting for the part to come in to see if that's the only problem. Thanks for the help.
J Lent
60
Nov 3, 2009 09:14 PM
mullishacrew
Jul 4, 2008 03:51 PM
Pat H
Nov 26, 2005 05:46 PM
first4age
Sep 7, 2005 11:28 PM
landscaper
Feb 16, 2005 04:21 PM
