Help!!!!!!!!!
Old Oct 20, 2006 | 09:28 PM
  #31
gfd121's Avatar
the sensor on the clutch shaft.is that the switch i need to replace??????
Old Oct 20, 2006 | 09:33 PM
  #32
John Faughn's Avatar
Do you have access to a wiring diagram ?
So you can follow that circut to each of the components to see where the power dose not go through .
Maybe some one here can link you to one , use a high lighter pen on the wiring diagram to follow the wire from starter back to ing. , then with a test lite check for + on both sides of every thing that circut/wire-color , when you find where its not going through then you've found the offending part .
Old Oct 20, 2006 | 09:39 PM
  #33
gfd121's Avatar
thanks, i think that hillcountry might have a good idea about the clutch switch. does anyone have a part #for it?/?
Old Oct 20, 2006 | 09:49 PM
  #34
gfd121's Avatar
Thank You All!!!!!!!!!!
This Is A Great Site!!!!!
Old Oct 20, 2006 | 09:52 PM
  #35
Hillcountry's Avatar
Here's something you can try (and I am not saying it is a good idea!) But if you unplug the electrical clip on the sensor. I think there is about 4 inches of wire. Is there any way you can bridge the connection to see if you can "fake the clutch being depressed?" I would hate to have you buy a new sensor and I am wrong about this. I would try to test it as much as you can to isolate the problem. Have you tested it yet?
What I am suggesting is creating a dummy plug or something.
Also do a search for Clutch switch or something like that and see if this topic has come up before. I have been trying to find more info...if I do I'll let you know.
-Geoff
Old Oct 20, 2006 | 09:53 PM
  #36
Is it working or are you just tired and happy?
Old Oct 20, 2006 | 09:56 PM
  #37
gfd121's Avatar
Hill
I Have Not Tried To Unplug Of Test The Sensor Yet. I Will Try Tomorrow. I Know What You Are Getting At. I Was Wondering If There Is A Part # Just To See About The $$$$.
Old Oct 20, 2006 | 10:00 PM
  #38
I don't know about a part number...sorry. I did find a post though where a guy with a 2001 got fed up with the clutch switch and bypassed the clutch switch and installed a manual switch. So I guess it is safe to jumper the circuit. At least you could find out for sure if it is the problem.
Good luck tomorrow. I will be out of town but I will check in at night. Hopefully you will get it working again. Keep us posted.
Good night,
-Geoff
Old Oct 20, 2006 | 10:02 PM
  #39
gfd121's Avatar
Tired
5am comes too early. thanks for your help!!
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
