Help!!!!!!!!!
Old Oct 20, 2006 | 07:05 PM
gfd121's Avatar
Help!!!!!!!!!
TRUCK WILL NOT START. JUST HAD THE STARTER REBUILT BUT NO HELP. LIGHTS COME ON.
Old Oct 20, 2006 | 07:23 PM
1-2-3's Avatar
Just a plain ole guy
Does it try to turn over? Just click? Do you have power at the selenoid? Do you have power at the starter when the key is turned?
Old Oct 20, 2006 | 07:28 PM
gfd121's Avatar
No It Does Not Turn Over. When I Take The Screw Driver To The Starter Bolt It Cranks Over And Runs. Thats How I Got Home Yesterday
Old Oct 20, 2006 | 07:50 PM
gfd121's Avatar
Any Sugestions????????????
Old Oct 20, 2006 | 08:00 PM
singleturnout's Avatar
bump!!!!!!!!!!!!!!!!!!!11
Old Oct 20, 2006 | 08:02 PM
gfd121's Avatar
Budlight Dont Cure Everything!!!!!!!!!!!!!!!!!!
John Faughn's Avatar
Not sure what your jumping , so to start fresh , use a test lite to see if you get power at the small wire at the starter , that wire comes form the ing switch , if there is power its the starter or battery connections - or + .
If no power then next the ingnition switch , but this is where it can splits off to other things [ not enough info in you sig. , M.T. or A.T. ] but both are sending power to the ing.sw. through a nutrual safety sw. ,
Start at those and see .
Old Oct 20, 2006 | 08:05 PM
Hillcountry's Avatar
Ok.aaahhh,
Is the ignition switch bad? If you bridged something with a screwdriver, perhaps you have a bad starter relay in the fuse box, or your ignition is wonkey....wonkey...a technical term.
I hate electrical gremlins
Old Oct 20, 2006 | 08:07 PM
gfd121's Avatar
Checked The Relay In The Fuse Box And Ok I Think??
Old Oct 20, 2006 | 08:11 PM
If you have a manual transmission, your clutch depressed switch could be bad
If you have a auto...maybe there is an in park sensor that went bad? I hope someone will chime in on this
I have a manual and your symptoms sound like what happens when you don't depress the clutch and try to start the truck...nothing.
-Geoff
Old Oct 20, 2006 | 08:13 PM
Diesel Dummy's Avatar
are all connections clean and tight,if you cross it and it starts you dont have juice telling the starter to work, check all connectiions are tight and clean, if thats done and no go, i dout the ing. switch is bad, it sounds like a relay or a bad wire connection somewhere.
Old Oct 20, 2006 | 08:17 PM
gfd121's Avatar
Just Checked The Small Wire On The Starter And No Juice With And Without The Ing On/off
Old Oct 20, 2006 | 08:20 PM
its gotta be a relay or a fuse somewhere, you wont get juice to it unless its in the start position anyway.
My hunch is the relay...do you hear a "click" when you turn the ignition? The relay will click if the starter soleniod is shot all you will is the relay click. If the relay is shot...you will hear nothing. I had this happen on a gasser once.
-Geoff
Old Oct 20, 2006 | 08:24 PM
gfd121's Avatar
No Click. I Changed Out The Relay With Another One In The Fuse Box And Nonething?????
