HELP with 05 Jetta TDI
Old Jul 12, 2007 | 06:55 PM
waldersha's Avatar
My wife called me at work today to tell me that her car won't start. The glow plug light is flashing and it chugs like it wants to start but won't.
I took the engine cover off to check the glow plugs and they all check out okay, but there is a plug with three wires right underneath the glow plugs that have been chewed off. (Time to declare war on the squirrels) I assume that this is the problem, but I have no idea what the wires are for.
Can someone confirm what these wires are for? I don't know if there is enough wire to splice them back together or not. Would they cause a non-starting condition?
Thanks for any help in advance.
Attached Thumbnails HELP with 05 Jetta TDI-chewed-wire.jpg   HELP with 05 Jetta TDI-plug-pic.jpg
Old Jul 12, 2007 | 09:41 PM
Buckshotmckee's Avatar
Can you get me a better/bigger picture, closer look? I can pull the wiring diagram tomorrow when I get back to work and let you know.
Old Jul 12, 2007 | 10:20 PM
waldersha's Avatar
Here is a picture of the thing (sensor?) Still not sure what it does, but it was covered in motor oil when it came out. Does that help?
Also found a part number on the wire I think. ABE038907319D. I guess I can call the dealership in the morning too, but I bet I'm going to end up paying for it. . .Doubt squirrel damage is covered by the warranty.
Last edited by waldersha; Jul 12, 2007 at 10:38 PM. Reason: additional information
Old Jul 13, 2007 | 12:39 AM
pind's Avatar
For all the world, that looks like an engine position sensor. Magnetic pickup unit.
Let me know if I'm dead wrong, it is definitely a mag pickup of some sort
Old Jul 13, 2007 | 07:41 AM
waldersha's Avatar
Nope, I think you are right on. I finally found the part number listed on a site from the UK. (They called it a timing sensor) NAPA calls it a crankshaft position sensor. I guess that would cause a no start. Just get to find a replacement today and hope it isn't too pricey.
Old Jul 13, 2007 | 08:24 AM
Looks like the crankshaft positioning sensor. This should be the pt #045 906 433 A. About $54 bucks from the dealer. This pt # should be stamped somewhere on the sensor.
rbuchana
Jun 1, 2006 08:48 AM
manganos
Mar 17, 2006 12:20 PM
Goldenbear
May 1, 2005 11:08 PM
ramcummins
Mar 18, 2004 01:55 PM
Goldenbear
Jun 21, 2003 06:28 AM
