heater fan not working
The fan has been working intermittently, when i turn it on it won't run, but when i hit a bump the fan sometimes works. It also will run after driving for a while. The fuse is ok, but is there a breaker some where or a resistor board, or maybe fan is seizing up?. Any info on system work be much appreciated.
Thanks
Troy
2004 Dodge 2500
4x4 QC CTD
Thanks
Troy
2004 Dodge 2500
4x4 QC CTD
Well I checked the motor and took it out, and tried to operate it and no go. So checked steering column and found burnt wire at ignition harness connector, took out and checked it out, taped for now to fix, and plan to add heavier wire to connector. Too bad a relay didn't carry more current instead of current setup. Thanks to the forums for advice and info
Troy
Langenburg
Troy
Langenburg
That was what I was going to say...
Several threads on burned connector at ignition switch.
Anyhow, keyed power goes fron ignition switch to fan motor. Speed control is on the ground side. Resister block is right next to the fan.
Sleigher
05-04-2017 02:12 PM
TurboPirate24v
12-16-2007 09:06 PM
