Blower Fan not working
Hey everyone... A day or so ago the blower fan in my truck quit working and it will not work at all on any setting combination...I checked the fuse and even replaced it to make sure..Well its in the single digits here and not much heat isnt very fun so any help at all is appreciated
Thanks,
Derek
Thanks,
Derek
I dont have anything apart right now because I'm at work and I dont have any place to get it inside to work on it..How hard is it to get to the connectors on it. I guess I'm basically trying to figure out if this is something that means the motor or a relay or something is definately out or if there is something else easy to fix that could cause this problem..
Thanks
Thanks
My '85 Ramcharger had this problem, but the power windows were dead also. Looking at the fuse block both of these are on the same main power tap. Mine turned out to be a bad ignition switch. $18 at Schmuck's, and it's good to go.
Jim Lane
Apr 5, 2020 06:03 AM
ChargerLighting
Dec 27, 2019 05:03 PM
Sleigher
May 4, 2017 02:12 PM
