headlights stay on after i take out the key!!!
Old Nov 15, 2004 | 05:37 PM
mr T's Avatar
this evening i got in the truck to pick up my dad and that little blue light inside on the dash came on...i never pulled the lil **** out twice so i dunno how that happened but no matter how id pull that **** that lil blue light stayed on....then i stopped shut the truck off and took out the key and shut off all the lights but that darn blue light inside was still on and the headlights were really bright and stayed on!!
k so right now i had to disconnect the batteries and am hoping for some help guys!!
Old Nov 15, 2004 | 05:39 PM
mr T's Avatar
ps....after disconnecting the batteries and then reconnecting them the first thing that happens is the headlights come on and that lil blue light on the dash....the truck isnt beeping or warning me that i left a light on or anything it thinks everything is cool i suppose
Old Nov 15, 2004 | 05:40 PM
Junk Yard Dog's Avatar
I had the same problem with my 98, and it was the headlight switch.
Old Nov 15, 2004 | 05:58 PM
Garnet Kid's Avatar
I would bet its the daylight running module on the drivers inner fender. About a 2 inch square black box. Disconnect it, that should put your lights out. Happened to me when on holidays in eastern canada. I think a new one was around 110.00 Canadian.
They are a sealed unit and is probably ozzing some goop out of it from the back side, and a prone to failure.
Old Nov 15, 2004 | 06:03 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Did you smell hot plastic lately?
The Headlight switches in the early 2nd genners had a bad rep for melting.
I think there was a TSB out for them also.
Old Nov 15, 2004 | 06:08 PM
mr T's Avatar
thanx boys im gonna disconnect that module first see whats going on there maybe i can clean it up or whatever and get things running right its the first time this has happened but then again it is a 95 so im starting to expect electrical problems to start coming up
Old Nov 15, 2004 | 07:00 PM
mr T's Avatar
i disconnected that module all lights work fine now i can control all the lights with the switches....whats the point of these modules in canada...am i supposed to have this?
Old Nov 15, 2004 | 07:22 PM
Sidewinder's Avatar
That module turns on your high beams at reduced voltage so that other vehicles can see you, or so they say, (daytime running lights) and yes all Canadian vehicles have them (haven't you noticed).
The only problem you will have now is that when you switch on your highbeams the indicator on the dash will no longer tell you the highbeams are on. If that's OK then you don't need to do anything else. If you don't like it buy a new module or check with a wrecker. Supposedly they are the same for many Dodge/Chrysler vehicles.
Old Nov 15, 2004 | 07:52 PM
mr T's Avatar
no i seriously havent even noticed
but things are fine now....i wonder what the next electrical problem's gonna be?? hmmm had the *click* syndrome with the starting...cleaned that...hmmm had the tps in the summer took care of that....whats the next common surprise ?? im approaching my trucks 10th anniversary (sniff sniff)
Old Nov 15, 2004 | 07:56 PM
Rattlerattle's Avatar
Starter contacts.
Don't worry though, they get better with age!
Old Nov 15, 2004 | 08:58 PM
Pop-Pop's Avatar
I'm not real sure what your're doing but, I assume that you know that if you turn off your ignition key while the headlights are still on, the lights remain on for awhile (just like they are supposed to). If you want the lights to be off, turn them off BEFORE you turn off the ignition key.
Old Nov 15, 2004 | 09:11 PM
mr T's Avatar
they dont have that option on the 95's pop-pop....new trucks they have the lights stay on for a min and turn off by themselves this is different. But it all working fine now. hey rattlerattle i took off the starter a month ago cause of the clicking turned out that one of the contacts was pretty fried so i sanded it off and sprayed some brake cleaner there...works fine now....but i never actually took the little contacts out of there i did it all while they were in the starter. Are they tough to get out for those who replaced them with the bigger contacts?? cause if its easy to get out then i'll take em off and sand them under as well
Old Nov 15, 2004 | 09:15 PM
mr T's Avatar
quick question....on the 1st gens do they have the same starters and on the same side?? cause there's one in my local junkyard in a dumptruck would be nice to have a spare for one day better than spending the 400$ or whatever these starters could cost
Old Nov 15, 2004 | 11:56 PM
dalton4's Avatar
I don't know about Canada, but there was a recall for the light switch in the US. Anyway, on my 96. Suggest you take your VIN number to a local dealer and see what they show for your truck.
Old Nov 16, 2004 | 07:33 AM
BBWD's Avatar
The starter contacts and plunger are real easy to replace once you have the starter out. About a 5 minute job. Get the heavy duty contacts and a new plunger from Foster Truck Parts, an advertiser on this site. Great service and good parts. Had to replace mine at 115k miles.
https://www.dieseltruckresource.com/...er+Truck+Parts
John (DH)
nitrous
Apr 21, 2009 04:44 PM
nitrous
Apr 21, 2009 04:43 PM
Ramified5.9
24
Oct 22, 2006 12:44 AM
big red psd cc
Dec 29, 2004 11:38 PM
8secondride
Jan 25, 2003 06:05 PM
