Headgasket popped
Old Jan 12, 2007 | 04:26 PM
Cummins Freak's Avatar
Originally Posted by dodgezilla04
i have carried a 6bt marine head, and I'm only 5'6" 165lbs, i cant be that strong.
FREAK of NATURE
Old Jan 12, 2007 | 04:33 PM
JD730's Avatar
Originally Posted by dieselrob
On the head wieght i think its a bit heavier than 90 lbs. The engine dry comes in around 1100 lbs. The head is some where in the 350- 400 lbs range. You will need an engine hoist just to get it out.
Engine hoist is an excellent idea, makes the job go a whole lot easier. Getting it off of there is one thing, putting it back on without damaging the new gasket will be tough without an engine hoist.
I know 350 to 400 is way too heavy. I put it solidly in the almost 200lbs category and I'm not about to run out an weigh my extra one, thats too much like work.
Old Jan 12, 2007 | 05:20 PM
francis212's Avatar
yea ill have to find a engine hoist, when you put the studs in do you do those first then try and line up all the holes lowering it or put them in after the head is down?
Old Jan 12, 2007 | 05:29 PM
XLR8R's Avatar
Engine hoist? !!!
Wazza matter, ya plannin to have kids someday?!
Old Jan 13, 2007 | 06:34 AM
JD730's Avatar
Head on the deck first then you can put studs in, thats why ARP broaches an allen wrench into the stud, so you can tighten them in without doing the double nut thing.
Don't forget to tap the holes deeper. Get yourself a good tap, cheap ones just make the job harder to do.
Pull the plastic plugs from above #5 and #6 cylinder too pull the push rods if you don't know already. The rest is just bolts, I did mine 3 times(don't ask), I can take a head off in 90 minutes by myself.
Old Jan 13, 2007 | 08:59 AM
francis212's Avatar
I've never done this what do you mean plastic plugs?
Old Jan 13, 2007 | 09:05 AM
francis212's Avatar
Originally Posted by XLR8R
Engine hoist? !!!
Whoa not just yet just turned 18 and i hope theres no kids on the way
Old Jan 13, 2007 | 06:05 PM
BCB's Avatar
BCB
i haven't seen them myself but i have read that there are plastic plugs in the cowl above cylinders 5 and 6 to pull the push rods out.
kawi600
15
Mar 7, 2009 03:27 PM
kas83
Mar 30, 2008 03:42 PM
JD730
Oct 14, 2006 09:18 AM
underwoodtransp
Nov 17, 2005 11:56 PM
TexasHardcore
Oct 19, 2004 12:55 AM
