Headgasket popped
Old Jan 10, 2007 | 09:18 PM
francis212's Avatar
Headgasket popped
Hi how's everyone doin tonight? Well i guess i'd be better if my headgasket didn't have to go on me today. Couple question im going to do head studs and o-rings. with probly a .020 gasket. would it be smart to get everything re-done valve guides resufaced magnafluxed whatever else there is to do , it didnt pop while boosting a lot i guess it was sometime coming just setting there and smelled some anti-freeze check and it was flowing out pretty good.
Old Jan 10, 2007 | 09:32 PM
PChouinard's Avatar
Just curious, is this the dreaded 53 block crack or a bona-fide head gasket leak?
Old Jan 10, 2007 | 09:49 PM
francis212's Avatar
no 53 block. thats about all i can be thankful for right at this moment i'm sure ill be happy again once its fixed it right up top on the back down the back of the block. so im guessing the head gasket i check the back core plug by hand just to make sure it wasnt something else but i feel it wet between the head and block so i'm hoping.
Old Jan 11, 2007 | 11:37 AM
dieselrob's Avatar
Where in Pa are you at? And what mods are you running?
Old Jan 11, 2007 | 12:49 PM
francis212's Avatar
chester county. i've done alot to it i knew this was going to happen just was hoping not right now but o well..
Old Jan 11, 2007 | 01:48 PM
elandon1201's Avatar
Its probably been a long time coming, we have me head off now and you can see around a few of the cylinders that Air has been eating away at the gasket for sometime before it finally blew through and started lubricating my engine compartment!!! ha ha
Old Jan 11, 2007 | 08:43 PM
francis212's Avatar
I guess it happens to the best of us i guess ill start the tear down hmm this weekend how heavy is that head?
Old Jan 11, 2007 | 09:10 PM
smokindog's Avatar
I read somewhere that it is in the 90lb. range.
Old Jan 11, 2007 | 09:20 PM
francis212's Avatar
that not bad i guess it just more akward then heavy. ill find out 1st hand soon enough
Old Jan 11, 2007 | 10:07 PM
dieselrob's Avatar
On the head wieght i think its a bit heavier than 90 lbs. The engine dry comes in around 1100 lbs. The head is some where in the 350- 400 lbs range. You will need an engine hoist just to get it out.
Old Jan 12, 2007 | 01:38 PM
francis212's Avatar
o dang 300lbs guess i'm gonna have to get a case of beer and get my buddies to help out
Old Jan 12, 2007 | 01:45 PM
mcoleman's Avatar
185 pounds
Old Jan 12, 2007 | 03:23 PM
johnh's Avatar
i think you are a bit over on the weight of the head , i'm not that strong, i think around 100
Old Jan 12, 2007 | 04:21 PM
XLR8R's Avatar
The head is quite a bit less than 350-400#!
Old Jan 12, 2007 | 04:22 PM
dodgezilla04's Avatar
i have carried a 6bt marine head, and I'm only 5'6" 165lbs, i cant be that strong.
