Had to be towed home today!
Old Aug 9, 2008 | 02:03 PM
JimonaWing's Avatar
I was pulling a small utility trailer with a lawn mower on it when suddenly no power.
The truck was still running but there was nothing when I stepped on the pedal. I pulled off to the side of the road and shut the truck off. I tried to restart in and it would not start. It would crank but would not fire.
I had it towed home and now I need advice on what to do next.
What do I check? How do I check?
Thanks for your help.
Jim
Old Aug 9, 2008 | 02:49 PM
elucho02's Avatar
was it smoking\knocking or trying to start?
Old Aug 9, 2008 | 02:52 PM
JimonaWing's Avatar
No smoking or knocking. It did not try to start. Just cranking with no firing.
Old Aug 9, 2008 | 03:39 PM
elucho02's Avatar
lift pump fuelfilter fuellines inj pump etc. email phone # to smhs98@embarqmail.com mabee I can help
Old Aug 9, 2008 | 03:49 PM
duner's Avatar
sounds like it ran out of fuel one way or another.
Old Aug 9, 2008 | 04:25 PM
rebal's Avatar
do you know anyone with a smarty or code reader?? Im thinking your vp 44 died
Old Aug 9, 2008 | 07:19 PM
blacksmoke99's Avatar
Can you hear your lift pump kick on? Does your wait to start light come on? Same thing happened to me 9 months ago and it was the ECM that went out.
Old Aug 9, 2008 | 07:39 PM
JimonaWing's Avatar
I can hear a "Buzzing" type of sound near the fuel filter after I tried cranking it. not sure if this is the lift pump. I am not to familiar with working on these diesels although I am quite mechanically inclined.
I'm not sure about the wait to start light. When I left the house, the truck started right up. The truck had not been started in over a month but it started without any problems. 10 minutes later... it died
Where is the ECM on these trucks and can they be tested?
Old Aug 9, 2008 | 08:31 PM
Purplezr2's Avatar
The buzz you hear is the lift pump, I would crack the banjo bolt on the vp with the key on and see if fuel comes out, if it does I would say Vp44
electrifried
Jul 21, 2012 12:36 PM
Box5
Jul 19, 2007 06:46 PM
53 willys
Apr 22, 2007 07:26 PM
z1bigtom
Aug 30, 2004 11:42 AM
