Grinding or Rumble
Old Nov 21, 2005 | 06:10 AM
poogan's Avatar
Unhappy Grinding or Rumble
I'm getting a grinding or rumble when I make a slow turn, I only get it at a very slow speed. I made an appointment to take it in today, any idea's. fMaybe I don't have enough slippage or could a brake could be locking up. Just trying to get some idea before I head to the dealer. I definately comes from the back end of the truck.
Thanks
Last edited by poogan; Nov 21, 2005 at 06:21 AM. Reason: Noise is from back of truck
Old Nov 21, 2005 | 11:53 AM
dodgediesel4x4's Avatar
Possibly a bad u-joint? or a bearing in the rear axle? You need to be more specific when describing the sound.
Old Nov 22, 2005 | 09:04 PM
mr T's Avatar
5 speed or auto?...
Old Nov 22, 2005 | 09:06 PM
mr T's Avatar
do u have ur foot on the go pedal while turning? ur truck will hop if u do that...otherwise could be a wheel bearing...are u absolutely sure its from the back of the truck?
Old Nov 22, 2005 | 09:10 PM
mr T's Avatar
aside from that it can be a worn out u-joint thats vibrating...could even be out of balance tire or tires...before my front wheel bearing seized on me and i had to change it i was driving with it while it was squeeking and in the process it damaged my tire internally...so i can detect a slight rumble on that tire still and its off balance ...getting new tires soon though
could be tires too...maybe wheelbearings in the rear
the rest of the guys will give u more ideas
Old Nov 22, 2005 | 09:52 PM
poogan's Avatar
Grinding or Rumble
Thanks for your reply's. The dealer checked the U joints bearings and found all in good condition. Changed the diff oil and added more slippage. Seems OK but will put it to the test tomorrow. If all is not right they will get it back PDQ.
Love this site and the great and quick response to situations.
12valve@heart
Oct 9, 2008 08:55 PM
gsbrockman
15
Oct 5, 2004 07:16 PM
Rammer64
Sep 27, 2004 08:28 PM
wooff
Jun 24, 2004 11:16 PM
cLAYH
Feb 6, 2004 10:59 AM
