Going into Limp Mode & P0217 & P2121 Codes
Old Aug 24, 2009 | 07:00 PM
Mark Hodowanec's Avatar
My truck has gotten a P0217 (Coolant Temperature Too High) & P2121 (Pedal Position Sensor 1 Performance / Rationality) code for the second time within the past week. Each time the check engine light comes on & the truck went into limp mode. The instrument temp gage was just under 200 degrees & the engine felt very cool to the touch (could hold onto upper radiator hose, put a finger on the exhaust manifold & keep it there for 1 second, etc.).
The second time it happened I pulled over right away to pop the hood & see if the engine felt hot. Felt cool, so went back on the road (still in limp mode) & drove for 15 miles (and still in limp mode). Pulled off the road & let engine idle for 5 minutes, then shut it down for 10 minutes. Went back on the road & no more limp mode, but check engine light was on. After 3 key cycles (off/on/off & pulled key out) the check engine light went off.
Now, last week I did a coolant flush, so when this happend the first time, I figured that I had an air pocket. But, I put on 750 miles between the first time & second time that this happened, so I don't think that it is an air pocket any more.
How can I check if I have a bad sensor or if the engine is overheating? Also, where is the sensor for the P0217 gage & the instrument gage? They can't be picking up off the same sensor.
Any suggestions?
Mark Hodowanec
Mar 10, 2018 06:43 AM
dodgediesel4x4
May 4, 2011 06:21 PM
Mark Hodowanec
Sep 1, 2009 08:17 PM
Mark Hodowanec
Aug 26, 2009 05:55 AM
swimmy
Dec 3, 2005 09:52 PM
